350z Rear Clunk. HELP, Ive tried so many things.
Old May 15, 2016 | 07:26 PM
PaintingStreets's Avatar
PaintingStreets
Default 350z Rear Clunk. HELP, Ive tried so many things.
Hello Im posting here as my last resort and hoping I can find someone that had my issue. I getting a clunking noise on the rear passenger side when i go over bumps in the road.
I already replaced the CV axle, removed the sway bar endlink for a test drive to see if that was the culprit, no luck. Rear interior is completely stripped.
This started when I switched to the PBM pro true coilovers from my stance oem type coilovers. I tried tightening the top coilover nut, and even swapped the two PBM rear coilovers, still does it on the passenger side. Car has welded diff and ASD hydro so maybe its my diff or subframe bushings after some abuse but they look and feel fine.
Ive also checked for anything hitting metal to metal under there, nothing.
Any suggestions would be appreciated as Ive researched alot and came up with no luck so far. Thanks.
Old May 15, 2016 | 07:30 PM
HRMoneyPit's Avatar
HRMoneyPit
Bushings
Old May 15, 2016 | 07:52 PM
PaintingStreets
Originally Posted by HRMoneyPit
Bushings
that's what i figured id might have to do, is there a good way to check to find the exact one thats bad?
Old May 15, 2016 | 07:59 PM
PaintingStreets
i can get a video tomorrow when im driving home from work on this nasty road so you can hear the exact noise.
Old May 15, 2016 | 08:00 PM
HRMoneyPit's Avatar
HRMoneyPit
Look at them lol
Get under the car
Old May 15, 2016 | 08:08 PM
PaintingStreets
Look at them lol
Get under the car
i know that as ive been under there all day and they looked and felt fine, no play in them, no cracks or anything. Ive been trying to find this noise for a few months now. I know what bad bushing look like and feel like due to i had a e36 before and i had to do the subframe and RTAB bushings.
Old May 15, 2016 | 09:15 PM
rawgarage's Avatar
rawgarage
Definitely bushings
Old May 15, 2016 | 09:29 PM
PaintingStreets
Originally Posted by rawgarage
Definitely bushings
alright well i guess there goes some of the money i had saved up for the vortech lol SPL solids for diff and subframe or is there a cheaper alternative with the same type of quality?
Old May 15, 2016 | 10:09 PM
rawgarage's Avatar
rawgarage
I sell SPL so lemme know...
But the bushings are made by white line and energy suspension I believe
Old May 18, 2016 | 06:40 AM
Deteria's Avatar
Deteria
Did you try replacing the shock mount bushing? Goes above the rear struts. I had the same issue until I had that replaced. Also there is a padding that goes where the rear shocks mount into the body that got worn over the years and I had that changed out along with the bushings.
See here for bushings:
Amazon.com: KYB  SM5482 Shock Mount kit: Automotive Amazon.com: KYB SM5482 Shock Mount kit: Automotive
Old May 18, 2016 | 11:13 AM
PaintingStreets
See here for bushings: Amazon.com: KYB SM5482 Shock Mount kit: Automotive
i have PBM pro coilovers so that shock bushing doesnt apply to me, as far as a padding on the rear shocks? what do u mean? if your talking about the little paper thin orange gasket. i have new ones it there but that thing only keeps moisture out, not really a "pad"
Old May 18, 2016 | 12:17 PM
dcains's Avatar
dcains
Go to Lowe's or Home Depot and get a sheet of valve packing, which is basically a piece of thin (maybe 1/8") pink rubber. It's in the plumbing section. Cut it into the shape of that useless paper gasket, and use it in its place. It's the only thing that worked to clunk in my car, and it's lasted for a few years now. Nissan replaced the gasket a few times under warranty, and the clunk always quickly came back.
Old May 18, 2016 | 07:57 PM
PaintingStreets
ill try that out if the bushing dont fix it. Got my SPL solid diff and subframe bushing today, so hopefully the clunk will be gone tomorrow.
Old May 22, 2016 | 07:40 PM
PaintingStreets
well due to u guys suggesting the diff/subframe bushings were bad, i got spl solid diff and subframe bushings. **** subframe bushings! never again. and guess what guys!?? the clunk is still there. ****in fantastic
Old May 22, 2016 | 10:56 PM
rawgarage's Avatar
rawgarage
Damn no way man
Old May 22, 2016 | 11:32 PM
PaintingStreets
Damn no way man
yea, ive contacted PBM about the rear coilovers maybe being defective, Ive had 2 sets from them in the past for s13s, loved em and no issues but idk what else it could be. imma try the thin piece of rubber on top of the coilovers like another person said tomorrow but i doubt thats my issue.
Old May 23, 2016 | 03:01 PM
PaintingStreets
Just an update, I called PBM and they are shipping me out two new rear shocks to try out to see if it fixes the problem, im just at a loss for ideas as I don't even wanna drive the car with this clunk anymore. If there is anyone who would like to hear a video of the clunking or any other info to help me out id appreciate it alot.
Old May 23, 2016 | 03:04 PM
travlee's Avatar
travlee
Master
PBM isn't know for quality stuff, but at least they are trying... did you try what Deteria stated? if not, do it when you replace them (but then you wont truly know what the issue is)
Old May 23, 2016 | 03:24 PM
PaintingStreets
ive never had an issue with PBM on two of my s13s but i knew i shoulda went with FEAL suspension. smh. ill do the rubber piece if the new shocks dont fix it
Old May 23, 2016 | 03:25 PM
travlee's Avatar
travlee
Master
i would do it the same time... so you don't have to take it apart twice... just my devalued 2 cents
