Overheating when boosting
Old May 30, 2016 | 04:39 AM
RodiZio's Avatar
RodiZio
Default Overheating when boosting
Hi, I'm having overheat problem with my twin turbo Z, the strange thing is it will run at normal temp until I use boost and then jumps right up in temp. Anyone got any ideas on why?
Old May 30, 2016 | 10:22 PM
dcains's Avatar
dcains
Boost = more hp = more heat. You may need to upgrade your cooling system, and/or add an oil cooler.
Old May 31, 2016 | 10:35 AM
iideadeyeii's Avatar
iideadeyeii
Stock cooling not working properly. I ran stock plugs and did not have cooling issues with a single turbo mounted behind drivers taillight and it gets very very hot in my engine bay.
Old May 31, 2016 | 02:18 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
thats a new location
probably failing hg.
Old May 31, 2016 | 02:45 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
These. ^^^
https://www.z1motorsports.com/coolin...or-p-3544.html
Other things to consider for a blown application: You might want to consider going to a slightly cooler thermostat as well. (But don't go too cold!) Stock is 170-deg, Mishimoto (and others) offer a 155-deg (or thereabouts). And auxiliary electric fans if the above doesn't do the trick.
Old Jun 1, 2016 | 06:19 AM
iideadeyeii
Haha I mean't headlight!!!, but even then it's a bad explanation for it
Old Jun 1, 2016 | 02:09 PM
MicVelo's Avatar
Can't tell from your pic but it looks (and sounds, from your description re: underhood heat) that your turbo install could benefit from a turbo insulator blanket. (And possibly OP's as well.)
http://ptpturboblankets.com/why_turbo_blankets.php
I've outfitted almost every turbo car I've owned (present turbos excluded... for now) - even transferred one from one car to the successor cars utilizing same G-T3 unit. Works great.
Old Jun 2, 2016 | 06:31 AM
iideadeyeii
I was actually looking into a turbo blanket last week. That video sold me where he puts his hand right on the blanket.
brians4130
Jul 7, 2016 10:46 AM
350zdorifto
May 28, 2016 02:57 PM
SM0KESCREEN
May 26, 2016 11:03 AM
sales@aamcomp
May 25, 2016 09:49 AM
Milosis
May 19, 2016 03:33 AM
