Weird clutch issue... Video link to help.
Old May 31, 2016 | 09:27 AM
DreamZcometrue's Avatar
DreamZcometrue
Default Weird clutch issue... Video link to help.
First things first, I have a video.
https://youtu.be/bbZWTk05f9U
I have an 06 350z. Not sure which trim. I think enthusiast. The guy I bought it from installed a "pro 2 clutch kit." He says its a racing clutched and Im inclined to believe him because 1st and second are pretty tricky. I looked up "pro 2 clutch" and I couldn't even find it anywhere.... So anyways, when it "pops" back out, it doesnt seem to interfear with the clutch at all. The clutch seems to be engaged and when the pedal springs back out, the car doesnt jerk or anything, but it is weird, and I don't think it should be doing this.
Old May 31, 2016 | 09:34 AM
travlee's Avatar
travlee
Master
normal, mine used to do that. embedding the video for ya also
Old May 31, 2016 | 09:37 AM
DreamZcometrue
350z clutch pop - YouTube
Did it really? Huh..... okay.. Well thanks! While I'm here, have you heard of Pro2?
Old May 31, 2016 | 09:45 AM
travlee's Avatar
travlee
Master
have not, but he could have meant he put a stage 2 clutch it in.
my pedal only did that when i swapped the master and slave out, at first it would stick in some (the distance your pops) and zspeed said it wouldnt hurt it, but if i wanted it to pop back up like yours is doing then i needed to adjust the push rod. i wouldnt touch it if i were you, just my opinion
Old Jun 1, 2016 | 07:21 AM
Doggman9's Avatar
Doggman9
If you don't like that you should check out the RJM clutch pedal assembly. In my opinion the assembly Nissan put in there from the factory is jacked up. It actuates like a f'n compound bow - not linear at all. I swapped over and recommend it to anyone who isn't satisfied with the OEM 350Z clutch pedal.
Old Jun 2, 2016 | 08:04 AM
DreamZcometrue
Sweet. Thanks for that.
CUL8ER
Engine Swaps
May 4, 2016 10:34 AM
Rev_Night
Drivetrain
Apr 18, 2016 07:53 PM
#1Pussologist
Apr 14, 2016 09:30 PM
grr01gsr
Apr 12, 2016 03:18 AM
Obadabot
Apr 8, 2016 10:02 AM
