Driverside window won't come back up
Old Oct 3, 2016 | 08:59 AM
mazzotta.al's Avatar
mazzotta.al
Default Driverside window won't come back up
I have intermittently been having the issue of the driverside window not coming back up. It goes down normally, then trying to get it back up either it doesn't do anything when i pull the switch up, or it tries to and then fails. I usually get it to come up after a few tries. Occasionally it works just fine the first time.
Is this the motor failing or is it the mechanisms that actually push it back up? I would think the motor is OK if it is working at all, and maybe there is buildup on the sliding mechanisms creating too much friction or something? Just spit balling here...can I diagnose the issue properly without taking apart the door?
Thanks
Old Oct 3, 2016 | 09:04 AM
travlee's Avatar
travlee
Master
next time hold the switch up and hit in the red circle area. but yeah, your motor is on the way out
Old Oct 3, 2016 | 10:54 AM
mazzotta.al
Man the diy on this repair looks brutal. Would it make more sense to have a shop do it? Does anyone have experience with the cheap motors? Found one for $60 rather than $140
Old Oct 3, 2016 | 11:05 AM
Syner's Avatar
Syner
Brutal?!
Pop the door panel and swap in the motor.
If you're looking for a budget motor, you won't like the price a shop will charge you to do this...
Old Oct 3, 2016 | 11:14 AM
mazzotta.al
It seems like it is very meticulous and time-consuming. Although the DIY i saw didn't have an estimated time, some people said they took a couple days to do it. Any idea what it should take? If I'm gonna spend half a day doing it, i wouldn't mind buying the motor and having my trusted shop do it for me if they will be more efficient. Just seems like there are lots potential for plastic clips to break and screws/washers to get lost, dropping the window into the door, etc.
Old Oct 3, 2016 | 11:17 AM
travlee's Avatar
travlee
Master
2-3 hours.... figure a shop is going to charge you about 100 an hour, plus markup the parts.
the only reason i had nissan do mine is because it was covered under the extended warranty.
i would get a motor from autozone that has lifetime warranty, if you get a cheap one you could possibly have to do it again sooner
Old Oct 3, 2016 | 03:39 PM
dboyzalter's Avatar
dboyzalter
6 inch cawk is my fave!
I got one from jc Whitney for like $48, it's about a year old and still works... It is a little glitchy about lowering the window when I open the door though.
Old Oct 4, 2016 | 06:29 AM
mazzotta.al
Yea I'm thinking about this one:
http://www.discountbodyparts.com/cat...?dbpcid=gglpla
Even the expensive one from Advance/O'Reilly for $140 has bad reviews.
Old Oct 11, 2016 | 06:45 PM
Spike100's Avatar
Spike100
It's a hassle replacing the window motor. I didn't want to replace this with a "cheepo" that might fail quickly. I replaced mine with one from Nissan, and it's worked fine for 7 years now.
Old Oct 12, 2016 | 04:15 AM
dboyzalter's Avatar
dboyzalter
You're going to jinx yourself talking about it if your original one didn't even last 7 years.
billybronco1
350Z Roadster
16
Oct 12, 2016 08:41 AM
Gearheadvr4
Oct 10, 2016 01:06 PM
sjtomcat
Oct 3, 2016 11:54 AM
MB33
Sep 26, 2016 02:48 PM
