Help, no start situation
Nov 16, 2016 | 02:05 PM
My car won't crank, the starter fuse in the interior fuse box is receiving no power (checked with test light), however the fuse isnt blown.
Does NATS also disable the starter?
Nov 16, 2016 | 02:53 PM
Nat's disables Ignition if I'm not mistaken. If your not getting power to your fuse box you have a big problem. You need to shoot wires!
Nov 16, 2016 | 05:00 PM
nats allows the starter to turn, but blocks fuel or ignition, not sure which one, but the starter will just turn and turn if that was the issue.
Nov 17, 2016 | 04:20 AM
Quote:
Originally Posted by
Conway_160
The fuse box has power, its just the starter fuse in the fuse box that has no power in the circuit.
Nov 17, 2016 | 04:38 AM
have you tested the starter? seems like you skipped the most basic step
Extreme Dimensions
Body Exterior
23
Jan 4, 2017 09:00 AM
CK12983
Nov 17, 2016 07:12 PM
Turbo_Tay
Nov 16, 2016 01:37 PM
