window issue
Old Apr 26, 2017 | 07:25 AM
twd123's Avatar
twd123
Default window issue
our 350Z has developed an issue with the drivers side window. It doesn't move the 1/4" up or down when opening the door or when you attempt to put the top down. This in turn will not let the convertible top activate. Is there a connection problem or motor death. It will engage sometimes if I bump the door panel, but that doesn't always work, and not a real solution.
Old Apr 26, 2017 | 08:08 AM
trusovici's Avatar
trusovici
not 100 percent sure, but it does sound like a failing motor as opposed to a connection problem.
Old Apr 26, 2017 | 08:38 AM
dcains's Avatar
dcains
When mine did that (both) Nissan replaced them under warranty. If you make the effort to search, you will find there are ways to clean and service the motor yourself.
Old Apr 26, 2017 | 09:30 AM
travlee's Avatar
travlee
Master
def going out
absurdparadox
Jan 27, 2022 06:51 AM
Axelrod
Nov 22, 2016 12:40 PM
Kiz350HR
Oct 31, 2016 04:58 PM
mazzotta.al
Oct 12, 2016 04:15 AM
yosip1115
Sep 28, 2016 05:54 AM
