TPMS connector issues
Old May 9, 2017 | 09:11 AM
TrapperJo's Avatar
TrapperJo
Default TPMS connector issues
I have followed all the posts pertaining to resetting the TPMS. I finally located the connector on the passenger side of my 2006 Z and cut the blue tape to separate it from the other harness only to find that the single wire is WHITE and not green? It was located right where the plctures in the posts showed. I'm unsure if I should proceed.
Old May 9, 2017 | 09:54 AM
Heel Til I Die's Avatar
Heel Til I Die
I think the wire (according to the FSM) is white on the 2006. Here's some pics from the FSM (circled in red is what you're looking for).
Old May 9, 2017 | 10:31 AM
TrapperJo's Avatar
TrapperJo
Thanks so much for the pictures and the fast reply. I found the connector right where the other post with pics(listed as a 2006) had indicated which shows it green. I just wish I could be sure that I'm not going to screw something up. I have looked all over and can not see an alternative to this connector. Guess I was hopping someone else had preformed the reset with the white wire. Again Thanks
