ECU problem
Old Aug 10, 2017 | 08:59 AM
Bruno.besa's Avatar
Bruno.besa
Default ECU problem
Hi everyone, I recently buying a 350z 2004 convertible manual,and is car not start the engine, I'm remove the Ecu to clean a terminals, the roof not work anymore, the internal painel illumination not work, obd2 reader not work, someone help me please?
This little white plug is off, somebody knows if it fits into some where?
Old Aug 11, 2017 | 09:05 AM
zakmartin's Avatar
zakmartin
Check the ECU fuse.
Old Aug 11, 2017 | 10:28 AM
Atreyu'z 350's Avatar
Atreyu'z 350
Hi.
Old Aug 11, 2017 | 12:07 PM
zakmartin's Avatar
zakmartin
OP: Out of curiosity, did you disconnect the battery before you started playing around with the ECU?
Old Aug 11, 2017 | 06:02 PM
Bruno.besa's Avatar
Bruno.besa
yes
Old Aug 11, 2017 | 06:58 PM
Atreyu'z 350
OP, check and see if your IPDM is wet. It is located within the battery compartment. Open the plastic covers to the fuse/relay boxes in there and check for water/moisture...
Old Aug 13, 2017 | 01:12 PM
Bruno.besa's Avatar
Bruno.besa
Default Found problem
Found the problem guys, the positive battery terminal
Old Aug 13, 2017 | 04:56 PM
carbuffguy's Avatar
carbuffguy
Wait, what the...
Old Aug 14, 2017 | 12:43 PM
zakmartin's Avatar
zakmartin
Holy crap! Looking at it, you can see its potential as a point of failure. I never noticed how flimsy that part actually is. Thanks for the follow-up, OP.
