TPS Sensor Potentially Bad?
Old Dec 22, 2017 | 05:28 AM
matholland618's Avatar
matholland618
Default TPS Sensor Potentially Bad?
Hey guys! Not too long ago I installed test pipes on my 03. Not too long after that (it started cooling off outside), I would notice that when I got in of a morning or evening and got in my car and would get on it, it would fall on it's face. It was weird because if I hold WOT, then eventually it would "kick in" so to speak and run like it should.
At first I thought that it was due to the test pipes since I've seen mixed things about them without a tune. Upon further investigation, I monitored my TPS on my way to work yesterday and noticed at WOT when it is doing this, my reading for it is only around 20%. It's like the TPS has a dead spot in it.
Is it possible that the TPS is bad, or is that potentially another issue with perhaps the electronic throttle?
When I get home from work, I'm going to hook my scanner up to it and do a relearn for the TPS and see if that changes anything.
Old Dec 22, 2017 | 08:25 AM
yosip1115's Avatar
yosip1115
Did you monitor throttle position sensor or throttle pedal position sensor
Old Dec 25, 2017 | 02:19 PM
matholland618
I was using my small handheld scanner instead of my good one, but I was monitoring the absolute throttle position, which I do believe is the TPS.
Old Jan 3, 2018 | 05:20 AM
matholland618
So I used my good scanner, and I am monitoring the TPS. The pedal tests fine. Looks like I'm going to be buying a throttle body.
Old Apr 29, 2018 | 06:30 PM
scoobasteve's Avatar
scoobasteve
Did the throttle body fix your issue. I have the same issue when cruising then trying to pick up speed it dips rpms for a sec then picks up. This started happening after installing berk test pipes
G-Man.uas
Oct 8, 2008 05:49 AM
funkymonkey1111
South West
15
Aug 3, 2008 04:07 PM
