High temperature when not driving
Old Mar 13, 2018 | 03:25 AM
mav4's Avatar
mav4
Default High temperature when not driving
Hello all,
I recently had a problem with my 350z. When I start the engine and get in traffic, so the car moves slowly, temperature rises a lot. Even touches the red bar zone.
Coolant starts boiling and even my engine generates a lot of smoke.
If I start driving again, fresh air enters and temperature goes down to normal levels.
I thought it could be a thermostat problem so I changed it. After a month, more or less, issues happened again.
I spotted that only one of both main fans works. I don't know if its normal or not.
What are your thoughts about it? I thought temperature sensor might do the issue too...
Thanks in advance
Old Mar 13, 2018 | 08:36 AM
jhc's Avatar
jhc
General & Tech Moderator
Could be many things. Get the fans working 1st. Other possibilities -
Air in cooling system,
Clog in heater core,
Restricted catalytic converter.
Search for the Burb thread to get the air out. gl
JCat's Avatar
JCat
With AC on full, both fans should run.
Z-Dub
Feb 16, 2012 01:59 PM
xthejokerx
Nov 3, 2010 11:21 PM
mrtomcat
May 8, 2008 09:24 PM
