350z high mount assembly replacement
Hi: can the led lights in the high mount assembly for a 2005 350z be replaced or does one have to replace the entire assembly? Is there a good source for the led lights and or the assembly?
Jeff
Washington, DC
Jeff
Washington, DC
You have to buy the whole assembly if you are getting it from Nissan. Part number appears to be 26590-CD00A. If you are buying used then you may be able to part it out. I'd shop online and see what you can find, or call a local salvage yard.
