03 Nissan 350Z HELP
Old Dec 18, 2019 | 07:02 AM
EWC8400's Avatar
EWC8400
Default 03 Nissan 350Z HELP
Okay, so I have an 03 nissan 350Z. I got it and the guy I bought it from said it had a bad 02 sensors so it wasnt running great.
The car lacked the power it was supposed to have. White smoke from the exhaust. Carbon build up on PASSENGER side spark plugs and intake. Runs fine in higher gears and rpms but tries dying in lower gears or neutral upon speed reduction. Have to feather gas and clutch to keep running. Throwing code P0300. Random cylinder misfire. I have read everywhere and changed all the things that came to mine but still the same result. Long story short:
Replaced all O2 sensors
Replaced Mass airflow sensor
Replaced all spark plugs/coils
Replaced all fuel injectors
Replaced all fluids
I'm out of ideas
Old Dec 18, 2019 | 07:19 AM
bealljk's Avatar
bealljk
Replaced all fluids
I'm out of ideas
Is the car overheating? How bad is the white smoke from the exhaust? Typically white smoke is coolant in the combustion - more specifically (likely) your head gaskets are blown. Perform (or have a shop perform) a compression and leak-down test. This will likely give you an idea what's wrong with the car.
Old Dec 18, 2019 | 07:27 AM
EWC8400's Avatar
EWC8400
The car has Zero heat issues and the coolant levels are consistent, but I will have it done.
Old Dec 18, 2019 | 07:50 AM
rustyschopshop's Avatar
rustyschopshop
First thing i would check with a random multiple cylinder miss before changing any parts would be vacuum and fuel pressure. If these 2 values are out of wack no matter how many parts you throw at it will fix the issue.
Old Dec 18, 2019 | 09:53 AM
EWC8400's Avatar
EWC8400
How can I check the vacuum and fuel pressure myself? Do I have to take it to a shop?
Old Dec 18, 2019 | 10:10 AM
iideadeyeii's Avatar
iideadeyeii
Compression test
Old Dec 18, 2019 | 02:44 PM
rustyschopshop
most auto parts stores have fuel pressure tester available to rent for free after they are return. Vacuum guage testers are cheap and can be picked up at same stores. Specs can be found by searching with google pretty quick.
Zack Miller
Apr 8, 2019 12:06 PM
ffwturboZ
Nov 26, 2014 12:43 PM
mcarther101
Aug 27, 2013 02:55 PM
soulfulstrum131
Nov 19, 2012 10:12 AM
DT91
Aug 3, 2012 09:24 AM
