p0300 then p0306 then back to p0300!
Old Aug 11, 2020 | 08:54 AM
JaeZ33's Avatar
JaeZ33
Default p0300 then p0306 then back to p0300!
I tried to do some research on these forums to have a checklist of what to do:
things i've done.
1) removed the ignition coils. a few of them had a little bit of oil, nothing drench or soaked. i tested their resistance with a digital multi meter and they read around 1.6-1.8. #2 look like it was replaced as the other 5 looked of the same brand.
2) removed the spark plugs, more than one had oil on it. i tried to check previous owner's maintenance records, spark plugs were replaced at 60k, car has 195k now. i am unsure if they were replaced since. the tips were kinda chalky, so i am already guessing worse outcome, worn valve/piston rings, etc. i've also read it could require spark plug seal and valve cover gasket replacement, but i wanted to do more troubleshooting before diving in the deep end.
3) i've read also you can test coil packs while engine is running. i unplugged #1, 3 and 5 and all changed idle. i also unplugged the MAF which change idle too.
4) i soaked up the oil in the wells as best i could, wiped down the plugs and the coils and put everything back in, cleared codes and started the car and waited then i got a P0306.
5) i swapped #2 coil pack to #6 and tried again, the P0306 went away and now i got a P0300 again.i also made sure #4 and #6 wires weren't swapped.
one thing i noticed. the i used my obd2 scanner and checked the sensors while the engine was running before getting the p0306: here is a link to that clip: https://photos.app.goo.gl/pqjVhfPx3yEuMDQc9
i dont know how to read everything, but i noticed the oxygen sensor 2 bank 1 and 2 are 0.28V, after i got the p0300 again bank 1 was 0.26V and bank 2 was 0.84v. Does this indicate something serious?
Can you test the ignition coil, with the intake tube removed and that bottom hose disconnected form it so i have access to the coil plugs or will it stall since there is a big vacuum leak without the intake tube installed?
Should i try swapping the #6 spark plug out with #2 and see if that changes anything at this point?
Does changing all the plugs and coils make a difference after the troubleshooting i've done so far? the coil packs should be good if they are reading OK on the digital multi meter right?
Cody Alexander
Aug 17, 2017 12:01 AM
vh5150
Apr 4, 2014 04:32 AM
Oso Zeta
Nov 30, 2013 02:47 AM
mcarther101
Sep 23, 2013 05:34 AM
sinasajadi
Jul 18, 2010 07:33 PM
