What’s the vdc fuse called
Old Nov 4, 2020 | 02:01 PM
JUSTINC2001's Avatar
JUSTINC2001
Default What’s the vdc fuse called
Hey guys what is the vdc fuse called the old owner pulled it and I want to reinstall it before winter I thought it might be a jcase fuse or a jcase mini fuse but might be wrong it’s the red 50amp one
Old Nov 5, 2020 | 04:06 AM
karlt's Avatar
karlt
A little punctuation would make your post much easier to understand. As for fuse identification, on my 2005 Z the VDC fuse is a 10 Amp fuse on the IPDM E/R. Check out the Service Manual for your model year to verify.
Old Nov 5, 2020 | 08:41 AM
JUSTINC2001
I couldn’t find it in the service manual but it goes here and on the fuse box it says vdc and above it it says fl50a
Old Nov 5, 2020 | 09:02 AM
karlt's Avatar
karlt
I found the one you're looking for in the Service Manual. It's either a JCASE or a JCASE Low Profile, depending on how tall it is. I suspect it's just as tall as the 40 Amp fuse at the other end of the box.
Old Nov 5, 2020 | 10:36 AM
JUSTINC2001
okay thanks I’ll try it I knew it was one of them just didn’t know which one
Edit: I belive it’s the low profile one because I stuck the tall one in and it sticks up like an inch above the rest of the fuses but it should still work the same just have to drive the car probably for the system to reset
RushNY
Jun 11, 2015 01:49 PM
pimpsta
Nov 17, 2006 12:27 AM
JP_WRX
Apr 6, 2006 05:07 AM
Vamos_Rafael
Dec 1, 2005 06:18 PM
Tizom
Drift
Nov 21, 2005 07:44 AM
