Knock Sensor Bolt Hole Damaged?
Old Dec 6, 2020 | 05:34 PM
ZScore's Avatar
ZScore
Default Knock Sensor Bolt Hole Damaged?
Hi everyone,
I've been working on replacing the knock sensor and harness on my DE 350Z, but now I cannot tighten the mounting bolt, even when I used a brand new bolt as a test. Inspecting the original bolt, it appeared there was at least part of a thread repair insert on it, so someone else must have previously replaced/removed the sensor (not 1st owner and have limited history on car's maintenance and repair).
I realize this means I need to address the likely damaged mounting hole itself, but wanted to ask how anyone else handled it/if they had this issue? I'm wanting to approach this in the most efficient way possible and have perused many threads about knock sensor replacement and how-tos, but did not see anything on this particular issue. I also know this isn't knock sensor specific as of course a stripped hole can occur wherever, just wanted to see if anyone else had experienced this in this location and how they approached the problem.
leafjerky
19
Jul 23, 2024 06:06 PM
sbp630
Apr 25, 2019 04:55 AM
jaredamman
Jan 6, 2014 11:37 AM
JohnnydVQ
Feb 14, 2011 07:42 AM
