diagnostic help
Old Apr 30, 2021 | 10:10 PM
skii_Z's Avatar
skii_Z
Default diagnostic help
help.
hello i recently got a 2008 hr Z and i’ve had one problem, which when i have my foot on the brake and when i press the gas pedal slowly the car tends to hesitate. could this be that i need to change the transmission fluid or what’s a possible solution? (it’s an automatic) aftermarket parks are only high flow cats from berk and intakes.
i’ve taking it to the shop to get a code read but the only thing that comes out are a code for the cats but i recently bought a month ago brand new.
Old May 6, 2021 | 07:15 PM
SnaykeByte's Avatar
SnaykeByte
Could be that the PCM does not understand why you would be on the throttle before releasing brakes?
Old May 6, 2021 | 07:26 PM
skii_Z's Avatar
skii_Z
Sorry i meant to say that when i have the car on drive and just let it roll on its own at a slow speed and when i press the gas pedal slowly it’s jerks/hesitate. The person i bought the car from said this “It was the solenoid in the old transmission. but it got completely replaced with new oil and new trans filter!”
Old May 6, 2021 | 10:00 PM
SnaykeByte's Avatar
SnaykeByte
Ok, I gotcha
Old May 6, 2021 | 10:06 PM
skii_Z's Avatar
skii_Z
Ok, I gotcha
could it still be that or should i look over the coil packs just to make sure, i’ve gotten it check for any codes but the only code that it reads it’s for the high flow cats.
Dcrunning
Sep 25, 2019 12:29 PM
OneLovelyZee
Aug 2, 2013 08:40 AM
Rocky350
Jun 1, 2009 12:05 PM
djtimodj
Apr 17, 2009 09:38 AM
