My mechanic charged me over 700.00 for a tune up then told me my motor is bad
Old May 7, 2022 | 12:58 AM
Rani Garner's Avatar
Rani Garner
Cool My mechanic charged me over 700.00 for a tune up then told me my motor is bad
I have a major problem and I feel I am being screwed over since I am a female.
I have 2005 350z touring with 177k miles. This car has never given me any trouble in 7 years. I took it in for a tune-up because it was running rough like the spark plugs were bad, also it smelled like fuel. This was just all of a sudden.
My mechanic was told me he did a tune-up and fixed the leaking valve covers or gaskets and I was supposed to pick it up that afternoon. When I call to see if it is ready he tells me I need a new motor. The cyl 5 is bad and can't be fixed he says. The compression test tested it at 90 lbs.
Not sure how that happened between the time he said it was just a tune-up and the phone call. The price was over 700.00 and the receipt says" needs a motor".
My question is shouldn't he have done that test BEFORE the tune-up? I am paying 700.00 plus for a tune-up on a dead motor??? Does that make sense?
My car runs just like it did before I took it in. Idles rough and runs rich. Is there any way that my car can be saved or do I need a motor?
I have taken care of this car just like I am supposed to so it isn't neglected. Also, I have smelled something burning for a few weeks now and have looked for the smell and couldn't find it. The engine light came on so I took it to auto zone before I took it to my mechanic. The codes mention a few reasons for my car misfiring and one had something to do with the drive train , I think. I told the mechanic this and assumed he would do his own diagnostic test on my car. Instead, he does a tune-up first and then a test. People take advantage of females and that pisses me off. I am going back down there to confront him if someone tells me he was wrong about charging me 700 plus for a tune-up then telling me it was a dead motor.
My gut feeling tells me that possibly something went wrong when they were working on my car that caused this problem since just earlier that day it was all good and almost ready to be picked up. He was acting strange and really short with me and normally he offers suggestions and explains. I know he did me wrong and I would like to know if I am correct, please.
Old May 7, 2022 | 05:47 AM
i8acobra's Avatar
i8acobra
This is what I think happened. You had a cylinder 5 misfire. He pulled the plugs to check their condition and found oil all over the #5 coil and plug. This indicates your spark plug seal is bad, which is very common on this car. The fix is to replace the valve covers. The seals are not serviceable. This is probably what the $700 charge is for. The normal diagnostic procedure for a #5 misfire wouldn't include a compression check if he found oil on the #5 coil. He did what any tech would do. The only thing I would have done differently is that I probably would have cleaned the coil and plug and swapped them with #3 to see if the misfire moved. If it did, then it's the plug or coil. If it didn't, it's the injector or a major component failure. I would have done that before replacing the valve covers. To help any further, 'm going to need to know exactly what codes you had/have and what exactly was replaced.
Old May 7, 2022 | 07:54 AM
JCat's Avatar
JCat
Get a second opinion. A cylinder compression check is an easy operation.
Old May 7, 2022 | 05:39 PM
Rani Garner
I am looking for that info to give you
Old May 7, 2022 | 05:48 PM
Rani Garner
my 2005v 350z has 177k miles. Last week the check engine light came on and I took it to Autozone to get the codes. I don't know what the codes are but the paper I was given suggested it could be the power train system and says to replace variable valve timing (VVT) solenoid. oh here it is... P0300 multiple misfires failure, also reads P0305: cylinder 5 misfire
Old May 7, 2022 | 05:59 PM
Rani Garner
Old May 8, 2022 | 05:35 AM
i8acobra's Avatar
i8acobra
Hmmm... He replaced the valve cover gaskets, but not the valve covers. The gaskets would have nothing to do with a misfire. I'd ask why he did that without getting permission first. Normally, if you bring a car in and ask for a diagnosis/repair of a particular problem, a tech won't repair anything not related without asking first.
Old May 10, 2022 | 07:41 AM
Rani Garner
Question
do you think my car has seen it's last day or is this a somewhat easy fix?
Old May 10, 2022 | 09:38 AM
JCat's Avatar
JCat
I have had a Ford dealer tell me once that I needed a new engine. It turned out to be a bad spark plug wire.
I would get a second opinion.
Old May 10, 2022 | 05:07 PM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Same here, I brought my diesel Excursion to a Ford dealer because it was low on power, they said I needed an engine rebuild and to do that they'd need to remove the body from the frame. The estimate was more than the value of the truck, back then anyways. Turned out I needed a new high pressure oil pump, about $500 total. Always get a second opinion.
Old May 18, 2022 | 09:47 AM
Rani Garner
Now my car isn't giving codes that cyl5 is bad anymore. Now it is at the 2 nd mechanics (2 weeks now) and he said it gives code 0011, something about a cam shaft sensor. Why would the other codes be gone and this one suddenly shows up? Did the last mechanic screw something up when he did a tune up?
PLease help. Your point of view is appreciated.
Old May 18, 2022 | 01:40 PM
JCat's Avatar
JCat
There are good mechanics and bad mechanics. That is why I suggested getting a second opinion.
Sadly, the same is true for doctors, dentists, lawyers, and humans in general. Sometimes you get lucky, and sometimes you don't.
Old May 18, 2022 | 07:15 PM
Rani Garner
The mechanic that has it now said the only code he is getting is 0011 something about cam shaft sensor A. What do you think about that?
Old May 19, 2022 | 05:16 AM
Dr Hoon's Avatar
Dr Hoon
5 Year Member
Has the new mechanic done the compression test and maybe a leak down test to confirm previous findings? Start with the basics.
Old May 19, 2022 | 08:44 AM
Rani Garner
I wish I knew what he had done I finally got him to call me back once and he told me it would be ready the next day but that was 2 days ago so I'm just going to go get it tomorrow no matter what because it's been two weeks and that's too long with no updates on it.
I trust him and I know he can't work on cars if he is being called all day. I will ask about what you mentioned.
Old May 19, 2022 | 08:46 AM
Rani Garner
Old May 19, 2022 | 09:49 PM
WYZIWYG's Avatar
WYZIWYG
If it's your Camshaft sensors, order both OEM replacements and get a new Crankshaft sensor.
Old May 21, 2022 | 05:30 AM
Rani Garner
Default 2 weeks now plus.. just want my car back.
. Thank you for the suggestion. I will for sure pass on the suggestion to the mechanic and he still has my car after all this time and I don't know that he's done anything to it he told me yesterday that he thought my fuel pump was going out but I don't want my fuel pump fixed because why would I put a new fuel pump on a car that isn't going to work now I'm starting to wonder if it's just another money scam I just want my car back
Old May 21, 2022 | 09:20 AM
bealljk's Avatar
bealljk
Maybe this was answered already but for the love of god, please do another compression test … If you truly have 90psi on one cylinder than do not spend another dime on this engine - it is basically toast …
Old May 24, 2022 | 04:16 PM
Rani Garner
Default On to the next mechanic tomorrow
Thank you for the advice I'm taking it to the third mechanic tomorrow and I will tell him to check the compression . when I picked it up yesterday at the second mechanic he told me that cylinder 5 was 140 lb that it was just fine , my engine was good but on the way home yesterday driving it it started smoking and making all these popping sounds underneath like something was shorting out. it died and then I barely made it to AutoZone. At AutoZone I got the code 03000 again and that's only code it gave. It was stinking like a smell I've never experienced.. There was something smoking from somewhere but it never showed it was running hot. When facing my car like when you open the hood on the right side is where it seems to be the location of the smoke , looked like underneath the motor.
