2003 350z
So recently my vdc and slip light turned on and caused it not pass 2k rpm’s and doesn’t let me accelerate also it stays on unless I turn the car off n off a couple times and drives like normal again but then after while it comes back and does the same thing again. Anyone run into this problem before if so what fixed the issue? TIA
Moved to a more appropriate forum. To the OP- your Z is in limp mode due to the onboard diagnostic system detecting a problem. Have you tried pulling codes from that system to gain some insight into that problem?
tmaia71
Aug 13, 2019 09:31 AM
