A/C Problem in my 03DE. I’ve tried everything!!!
Yep. As the title says, I have been trying to fix a problem with my vents since I bought the car in January. The air flow will not change direction! If you change it to feet it blows through the dash; if you change it to defrost it blows through the dash; if you change it to dash it blows through the dash…I don’t know what the problem is
Things I’ve tried: I’ve replaced the Blend Door Actuator & the Mode Door Actuator. I’ve replaced the white ribbon that comes off of the HVAC control ***** & the control ***** themselves.
I don’t know what the next move is. The A/C sounds like it wants to change direction when I try it because the air sort of dies down from full
blast and then picks back up and blows through the dash.
Any help would be much appreciated!!
350z wn
May 24, 2022 10:08 PM
