TCS and Slip light on 350z enthusiast
Old Oct 22, 2022 | 08:26 PM
kayocco's Avatar
kayocco
Default TCS and Slip light on 350z enthusiast
04 350z Enthusiast coupe manual trans TCS and Slip light on dash permanently
Clicking the tcs off light in the car does nothing. But the traction control feels like it’s still working.
Any suggestions for a fix?
Last edited by kayocco; Oct 22, 2022 at 08:32 PM. Reason: misspell and details added
Old Oct 22, 2022 | 09:19 PM
MicVelo's Avatar
350Z/370Z Tech Moderator
Pull codes.
Possible easy fix like cam and crank sensors (replace all with Nissan sensors even if only one code show up).
Have you done anything with wheels/tires lately? Could also be tire sizing.
Old Oct 23, 2022 | 11:23 AM
kayocco's Avatar
kayocco
Originally Posted by MicVelo
Pull codes.
Recently put all new rubbers on all the tires. How could that effect to tcs or slip?
Old Oct 23, 2022 | 11:30 AM
i8acobra's Avatar
i8acobra
Are they factory sized? If not, that will cause the light.
Old Oct 23, 2022 | 12:02 PM
MicVelo's Avatar
As cobra said, if you're on OE sized tires (or equivalent diameter) upsized, e.g. 18 to 19, no issues. But, if you went to a size that was square (all four corners same) or exceeded diameters causing the front and rear tires to be less or greater than 3% (+/- 0.25%), this will cause the car's ECM to detect that one end is rolling faster than allowed and interprets this as wheelspin (front end washout or tail slide) and invokes traction control on the offending tire. Wheel speed sensors send such rolling rates to the ECM several times per second.
But I still consider a cam or crank sensor a high er possibility and easy enough to track down by pulling the DTCs (codes).
VqBrickYard
Apr 22, 2013 12:43 PM
Qless
Jan 11, 2013 05:13 PM
rockinbboy
Feb 28, 2007 10:49 AM
fanatic6711
Jun 23, 2003 12:17 AM
