2003 Nissan 350z stalling out
Old May 7, 2024 | 10:58 PM
Frazux's Avatar
Frazux
Exclamation 2003 Nissan 350z stalling out
Hey everyone,
About a year ago, I snagged a manual 2003 Nissan 350Z, but it came with three bad coil packs. I swapped them all out for new ones, along with fresh spark plugs, to fix a misfire issue caused by faulty valve cover o-rings. Replacing those rings, covers, gaskets, and adding a new PCV valve did the trick.
However, lately, I've been dealing with intermittent stalling and a misfire again. I tried cleaning all six spark plugs and checked each coil pack individually, noticing changes in idle when unplugged. (I've yet to resistance test them but they're <1 year old, I suspect it could also be a dead ignition coil due to the P0350 code)
I also threw in a new crankshaft position sensor and did an ECU idle re-learn, which seemed to help a bit (The car developed a really lumpy idle and then would struggle to start prior to doing this). I've got camshaft position sensors lying around, but I haven't installed them yet. Oddly, no check engine light is on.
But the misfire persists, and the car often stalls when the revs drop. I ran an ECU scan and pulled these codes:
- P1615 - Status 3 (Difference of key)
- P1212 - Status 1t (TCS/CIRC)
- P1614 - Status 1t (CHAIN OF IMMU-KEY)
- P0350 - Status 1t (IGN SIGNAL-PRIMARY)
- U1001 - Status 1t (CAN COMM CIRCUIT)
- U1000 - Status PAST (CAN COMM CIRCUIT) [IPDM E/R]
Any ideas or suggestions on how to tackle this issue would be much appreciated.
Cheers,
Fsrph
Aug 24, 2023 04:41 AM
zd161201
Aug 13, 2023 06:22 PM
Verokosky
Feb 7, 2021 11:11 PM
Cameron Seibert
Jul 26, 2018 08:50 AM
matt_z33
Jun 25, 2015 11:49 AM
