Instrument Cluster issues - 2006 Base 6 Speed Manual Trans
Old Nov 1, 2024 | 09:25 AM
TexZan's Avatar
TexZan
Default Instrument Cluster issues - 2006 Base 6 Speed Manual Trans
Hey all. Looking for some help troubleshooting my Instrument cluster and pods. I bought the car off the lot 18 years ago and I'm the sole owner (just over a 100k miles). I've taken very good care of it and it runs great. Starts up fine, dash and pods light up. The digital pod cycles and shows values, but the oil and voltage are not showing reading (sits at zero). On start up, steering wheel instruments show readings, but after a few minutes, the tachometer and temp dials drop to zero. Nothing changes with the car though, it drives normally and there's no change in idle or engine behavior when this happens. Over the first 10 - 15 minutes of driving, the tachometer and temp randomly give readings and then drop off until it "warms up" and eventually stays on (like you would expect normally). Weather doesn't seem to make a difference. The pods stay lit up, but the oil and voltage never give reading (stay flat at zero). Speedometer and fuel dials always function even while the tach and temp are acting screwy. I've googled everything I can think of and can't seem to identify it. Hope one of you have seen this. Thanks
Justin101714
Dec 17, 2020 05:49 PM
Chilly604
Apr 25, 2013 04:13 PM
tszyuenc
Nov 30, 2012 03:06 AM
tennis_pr0
Jul 18, 2012 08:11 PM
Konvict
Dec 9, 2008 10:31 AM
