2006 Revup Bank 2 Exhaust Cam Timing Issues
Old Aug 26, 2025 | 06:38 PM
350TwizZ's Avatar
350TwizZ
Default 2006 Revup Bank 2 Exhaust Cam Timing Issues
Hello all first post here but I’m a frequent viewer, I’ve got a 2006 350z Revup with 105xxx kms I’ve been having a surging issue that under no load when I attempt to hold rpm’s at 2000 it bogs down by 100-200 rpm and jumps back up rapidly almost sounds like launch control for these cars through Uprev.
When I log this action it shows my exh cam adv bank 2 is bouncing from 40v to 0v as well as the exh cam sol bank 2 is bouncing up and down as-well this is the only rpm that this happens… Nissan told me today after $500 it’s my aftermarket intake I’ve had for 4 years no problems prior so they can get bent. I have a p0157 and p0159 both are for bank 2 sensor 2 which I know has a leak due to some bad welding on an 02 bung but this problem was prevalent before the original bung snapped off.
I’ve done the resets and I have NDS2 to do them as well I can do the pedal dance in my sleep the only reset I can’t get to function properly is the Exhaust timing relearn as it needs to rpm to hold between 1800-2000 for 20 seconds but it’ll always drop out of the range before the 20 seconds is up
Any ideas are greatly appreciated I know I need to swap the sensors to see if the timing issue changes banks but that’s about all I haven’t tried….
(log from NDS2)
https://www.reddit.com/r/350z/s/7rNJ6cGuzR
The car has all new
Camshaft Sensors
02 Sensors
Coils and Plugs
Bank 2 VVT sol.
Gallery gaskets
Upper and lower plenum gaskets
PCV valve
“Aftermarket Mods”
Aluminum valve covers
Motordyne exhaust
AFE tekeda intake
Old Aug 27, 2025 | 12:11 PM
icer5160's Avatar
icer5160
Did you use OEM parts when replacing the sensors, coils, solenoids?
Is your PCV system properly sealed up to your intake? (no vacuum leaks).
-Icer
sazzy06
May 12, 2023 06:39 PM
ericjackson
Aug 31, 2015 02:03 PM
bigcjohnson2003
Mar 14, 2015 09:00 AM
overZealous1
Mar 21, 2006 11:04 AM
