Tire Feathering caused by tires not suspension
Old Mar 10, 2004 | 11:13 AM
stx's Avatar
stx
Default Tire Feathering caused by tires not suspension
I was on tirerack.com reading the reviews on the Bridgestone RE040s. It seems like everyone that has them has tire feather no matter what type of car. This leads me to believe it isn't the suspension on the Z, its the tires. Anyone change their tires to a different brand and still have tire feathering?
Here is the link to the reviews.
Tirerack Reviews
Old Mar 10, 2004 | 12:55 PM
Apexi350z's Avatar
Apexi350z
Charter Member #50
I had Bridgestone S03, didn't have feathering.. Changed them out when it hit 10,000 miles.
I am using Falken FK-451 now, and I have 6000miles so far, and feather is back
So I don't think it matters what brand of tire it is..
Old Mar 10, 2004 | 01:23 PM
stx's Avatar
stx
Thanks for the input. I was getting excited thinking all I had to do was change to a different type of tire.
Old Mar 10, 2004 | 01:42 PM
SungNamZ's Avatar
SungNamZ
Might want to check out the latest issue of "Sport Z Magazine. An article on this subject and what should be the TOE setting.
Old Mar 13, 2004 | 01:00 PM
bosotheclown2002's Avatar
bosotheclown2002
Nice "tease" but since it is not sold on news stands and they do not publish current articles on there web site there is no way for any of use to see the article you are refer to.
Old Mar 18, 2004 | 07:34 PM
johnsZ's Avatar
johnsZ
I just had the 040 tires replaced- one of them threw chunks of the tread blocks, and started to separate from the belts, as well as feathering even after the dealer had switched them from side to side- this only lasted about 1000 miles before catastrophic failure.
The treadwear rating on the 040's is only 140 by the way. This means that you can expect 10000 miles or less. I have found since getting the new tires, they work better at 38 to 40 pounds than at the recommended pressures. A bit stiff, but the wear seems more uniform. The limit for these tires is 44 pounds based on the sidewall data, although they also state do not mount on the rim above 40 pounds.... a bit confusing. good luck
350Z_Al
Oct 29, 2020 07:44 PM
