Window Button Problem
Old Apr 14, 2004 | 10:35 AM
nmilsaps's Avatar
nmilsaps
Question Window Button Problem
Recently, my driver's side window will get stuck and not work. When I push the button, nothing happens. So I keep pushing or give it a little "love" tap and it seems to finally work. Is it in the switches? anyone else had this problem?
Old Apr 14, 2004 | 06:28 PM
sarahbelle78's Avatar
sarahbelle78
Default Re: Window Button Problem
YES! Except it's the passenger side. I began having problems shortly after installing new speakers. I am wondering if it may be related to the fact that the entire inside door panel had to be dismounted for the installation.
My window first started to gradually roll down upto 2 inches by itself. Tweaking with the window itself helped at first, then the button wouldn't respond intermittently and then it stopped all together. And the window dropped 3 inches besides, and wouldn't respond to anything.
I'm curious if others have the same problem. Have you heard anything?
Sarah
Old Apr 15, 2004 | 05:50 AM
nmilsaps's Avatar
nmilsaps
It happens to me most of the times when I crack the window, roll it down about 2 inches. And leave it for about 10 minutes or so, then when I push the button to roll the window back up, it just won't work. I even tried one time from the outside with the key in the door to roll it up, but that wouldn't work either. My door panels were taken off for the grease streak window fix, so maybe that's the culprit. I'm thinking it's maybe something with the wiring for the button or the motor could be going bad.
I'll probably end up taking it to the dealership sometime. Let me know if you beat me to it.
Old Apr 15, 2004 | 06:44 AM
mode101's Avatar
mode101
Default Re: Re: Window Button Problem
Sarah
Do you think the nissan techs will see you installed speakers and cancel the warranty because they think that something was messed up during the install ?
Old Apr 20, 2004 | 06:56 AM
nmilsaps's Avatar
nmilsaps
ever since i posted, my window seems to work now... Do our cars read these posts too?
Old Apr 27, 2004 | 08:13 AM
nmilsaps's Avatar
nmilsaps
Finally took my car to the dealership... they are going to replace the motor for the window. I'll pick the car up later and let you know more.
Old Apr 28, 2004 | 06:34 AM
nmilsaps's Avatar
nmilsaps
Update:
The window motor was sticking, needed to be replaced.
The part was something like: $280.
Out of pocket experience: $0
Covered under warranty: priceless
Uriyo_
Sep 8, 2021 08:46 AM
TDPrank
Sep 28, 2015 06:29 AM
