Does warranty cover rubber mouldings?
Old May 27, 2004 | 11:46 AM
mwaller's Avatar
mwaller
Default Does warranty cover rubber mouldings?
One of the rubber molding / weather stripping pieces between the window and door frame is torn. I think that it tore because my window regulator is not adjusted properly, and forces the window higher than it should. Are rubber parts covered by the warranty, or am I out of luck?
Mika
Old May 27, 2004 | 03:44 PM
jackwhale's Avatar
jackwhale
If the tear in the weather stripping was caused by a malfunction in the window regulator, it definitely should be covered. I certainly would explain it that way when you talk to the dealer.
pictures?
Old May 27, 2004 | 03:56 PM
JonsilvZ's Avatar
JonsilvZ
I have the same tear on the pass side. Had it since I got the car. You cant hardly see it. So I just left it.
Old May 27, 2004 | 04:15 PM
mwaller's Avatar
mwaller
on my car, it's noticeable because the triangular flap of rubber sticks out and flaps in the wind... no good...
I can try to get pictures later...
Mika
ablaine
Nov 29, 2016 10:13 AM
2ndchanceZ
Oct 26, 2015 08:03 PM
BOATS N HOES
Lighting
Oct 13, 2015 09:07 AM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
EnjukuRacing
Sep 30, 2015 06:55 AM
