film/residue on inside of windshield
Old Jun 4, 2004 | 03:37 AM
piston's Avatar
piston
Default film/residue on inside of windshield
Does anyone else have an obnoxious smelling film being blown (from the ventilation system) onto the inside of their windshield? The film looks a bit like a white powder and it is slighty oily. It is not easily removed from the windshield. Could this be residue/libricant from the A/C refrigerant? Can anyone provide any info to help correct this problem? P.S. The cooling system has not lost any antifreeze and a pressure test showed no antifreeze leaks, so I have ruled out leaks in the heater core.
Old Jun 8, 2004 | 02:17 PM
jackwhale's Avatar
jackwhale
A/C refrigerant shouldn't be able to blow into your car through the ventilation openings.
There is a somewhat waxy/oily film that gets on the windshield when it is hot. I assumed that this was the volatile hydrpcarbons and such leaching out of the interior plastic.
Old Jun 14, 2004 | 08:14 PM
johnsZ's Avatar
johnsZ
This is probably the outgassing of the interior plastics. I am in AZ and the problem is not very noticable. You can mix a bit of white vinegar and water (about 10% vinegar) put it on a cloth and wipe a couple times. Then, wipe with water on a cloth, then use a good glass cleaner and soft cotton towels, and it should look like new.
Old Jun 15, 2004 | 06:16 AM
mp3car's Avatar
mp3car
also, make sure not to use things like amorall on your dash(doesn't matter if it's regular or low gloss).
Old Jun 17, 2004 | 07:34 PM
myz8a4re's Avatar
myz8a4re
i too occassionally get this white residue when the car sits on hot days. i just use a heavy dose of windex all over the winshield, then i use the windex wipes over that & it cleans it up pretty nicely. its happenned twice so far since its been gettin really hot here in florida & i believe its starting to do it again. i remember this happening in a few previous cars ive had & it turned out being the scotchguard on the apholstry. in time it stopped fogging up...im hoping for the same with the z...........
-justin
3vilbunny
Jul 18, 2017 05:10 PM
Justin100
Nov 29, 2015 03:58 PM
kyin
Oct 15, 2015 05:54 AM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
PureR3d
Sep 10, 2015 06:23 PM
