Engine STALLING at idle
Old Aug 30, 2004 | 09:00 PM
rodH's Avatar
rodH
Default Engine STALLING at idle
anyone else have this problem. Car has only 8k miles on it, and have had it for about 2-3k with all the mods listed in my signature.
Anyone else have this and how can I fix it. The idle is all over the place, and sometimes stalls.
THOUGHTS???
Old Aug 31, 2004 | 02:11 AM
FLZ's Avatar
FLZ
Default Re: Engine STALLING at idle
THOUGHTS???
Run a check on all wiring harness connections. Maybe Oxygen sensor? Good luck...
Old Jan 8, 2008 | 07:41 PM
streetxtreme's Avatar
streetxtreme
i am having the same problems too....anyone solve this yet?
Old Jan 9, 2008 | 06:54 AM
Corradoslc7's Avatar
Corradoslc7
rodH, I don't see your mods listed and they might help with the diagnosis. But start checking for vacuum leaks.
Old Jan 9, 2008 | 07:10 AM
Yangsta's Avatar
Yangsta
i had the same issue with mine a couple weeks ago, happened i needed to replace my battery.
Old Jan 9, 2008 | 10:10 AM
HondaKiller's Avatar
HondaKiller
Throttle Body Reset?
Old Jan 9, 2008 | 10:40 AM
nadeemp8's Avatar
nadeemp8
Had this happen on my maxima right before I sold it for the z, turned out it was the idle air control valve and it was having the exact same problem you are describing...
Old Jan 9, 2008 | 10:45 AM
buzzardmountain's Avatar
buzzardmountain
rodH.....that's a username from way back.....haha....
bumping a 3 1/2 year old thread FTL...!!!!! lol
Old Jan 9, 2008 | 12:23 PM
Corradoslc7
I was going to say that it could be the IAC valve, but then I saw that the OP only has 8k miles on his Z. The IAC usually starts acting up on older higher mileage vehicles, mostly due to carbon build up or age related.
Old Jan 9, 2008 | 03:06 PM
djclongisland's Avatar
djclongisland
check your vac lines
liqalu04
Jan 2, 2022 12:58 PM
sherm
Apr 11, 2020 05:21 PM
Fixxxercask
Nov 9, 2015 11:10 AM
