Need help replacing rear pads
Old Sep 28, 2004 | 06:22 PM
ISH's Avatar
ISH
Default Need help replacing rear pads
Hey guys,
I've already done my front brakes and now I need to replace my rears (non-brembo). Are there any additional steps involved in replacing the rear brakes?
Thanks in advance
Old Sep 29, 2004 | 05:40 AM
GATORZ's Avatar
GATORZ
Default E-BRAKE ADJUSTMENT
The one thing you may want to make note of is the hole (has a rubber plug in it) that is used to adjust the e-brake(hand brake). It's between the lug studs and must line up with the adjustment screw underneath or you will have to take it off again to adjust the hand brake in the future. Thats the only big difference I seen from front to back.
Dan
Old Sep 29, 2004 | 10:49 AM
ISH's Avatar
ISH
Default Re: E-BRAKE ADJUSTMENT
Thanks. I just changed them. Very straight forward. Took me a whole 30 minutes.
Question: I have a lot of rust on my rotors. How bad is that for the braking system? How should I remove it? I heard of people using sandpaper.
hulkout
Apr 28, 2017 09:00 PM
350Z Project X
Suspension
Oct 10, 2015 09:23 AM
samansharif
Sep 25, 2015 12:31 PM
