Heater blows cold when at idle..
I'm brain-storming here:
If your coolant is full, listen for a small hissing from under the dash. At idle, the engine vacuum is low and may not be sufficient to keep a gate valve open that channels the hot air into your ducts. You may have a vacuum leak.
