rearview mirror rattle
Old Nov 16, 2004 | 08:33 AM
350ZOWNZ's Avatar
350ZOWNZ
Default rearview mirror rattle
My rearview mirror rattles when going over rough roads. It is not the plastic piece covering the wire because i did the TSB and when i hold the the mirror itself it stops. Any fix to this? Getting annoying. Thanks
Old Dec 22, 2004 | 03:20 PM
jc149's Avatar
jc149
Mine rattled too. Complained to the dealer, they replaced under warranty. New mirror does not rattle.
Old Dec 23, 2004 | 12:21 AM
Sins4u33's Avatar
Sins4u33
friend has a system....one day he had it "bumpin" and BOOM the rear view mirror fell right off....interesting...
Ben
Old Jan 1, 2005 | 11:01 PM
peterhong's Avatar
peterhong
I do believe there is a TSB related to this as well. In my car, I have the same exact thing but I just simply "Squish" the mirror for a sec and the sound goes away for the duration of the ride. Of course it does come back shortly after, but I'm just too lazy to get the mirror replaced and have to reprogram my homelink controls cause I cant find the remote transmitters anymore.
Old Jan 2, 2005 | 07:38 AM
mtscanlon's Avatar
mtscanlon
The TSB is for the plastic harness cover for the from the back of the mirror to the ceiling... This is not fixing the problem with the mirror itself.
The problem is the casing seems to snap together and the front and back pieces of the plastic casing must have enough of a gap and flex to cause this vibration
I have had it in many times, but the "problem can't be duplicated" by the dealer.... Maybe I will have to go to a different dealer. (or else, maybe some silicone calk or something....)
Old Jan 5, 2005 | 12:09 PM
imalazeeass's Avatar
imalazeeass
i told them about it and they installed a "fix" to my rear-view mirror as indicated on the piece of paper. Well, the so called "fix" didn't do crap.
Old Jan 11, 2005 | 06:17 PM
TELCO119's Avatar
TELCO119
I have the exact same problem, and one of these days I'll get off my lazy butt and do something about it. Get yourself a small piece of felt.......... cut it into really small pieces. Use a screwdriver to lightly pry the two halves apart underneath the mirror itself. Add a piece of felt. Problem fixed, the felt will stop the two pieces of plastic from vibrating together. Repeat as neccessary with entire dashboard/plastic interior.
What really pisses me off, is that I've owned many vehicles with mostly plastic interiors. Dodge and Chevy put little felt pads EVERYWHERE to prevent interior noise. It costs a total of $.08 @ the factory. I have two brand new Nissans and every square inch rattles/squeaks/creaks/vibrates. After all the money I've spent this year, I am now responsible to remove both interiors and re-install them with little felt buffers. For some reason, it's a widespread problem with Nissan. Everybody I know who has owned a Maxima/Extera/Pathfinder/Murano/Z has the exact same complaint, and it dates back several years. You can complain to the dealer, but if anything gets done, they usually cause more damage than good. (Fix the squeak, but scratch the dashboard). The best bet is to use felt pads as needed/ where needed.
Sorry for rambling, it really gets me upset when I think about it.
JjL
East Canada
Jun 12, 2019 03:04 AM
bcoffee20
Nov 19, 2015 06:39 PM
LunchBox20
Oct 20, 2015 10:22 PM
Ryan Bonner
350Z Roadster
Sep 8, 2015 04:16 AM
