Tein: S. Tech vs. H. Tech
Old Oct 19, 2006 | 11:14 AM
Mazinger Z's Avatar
Mazinger Z
Default Tein: S. Tech vs. H. Tech
2 questions:
Does anyone have pics of these two? I want to compare the ride height.
How's the ride of either one of these as compared to stock? I'm probably going to get a set before I get $$$ for the coils.
Old Oct 19, 2006 | 01:39 PM
Mazinger Z's Avatar
Mazinger Z
If you have either one, can you post pics and impressions? Thanks.
thirty5ounces's Avatar
thirty5ounces
+1 any pics i want to see also
Old Oct 19, 2006 | 01:42 PM
SinCity350Z's Avatar
SinCity350Z
Track Whore
I have the S-Techs on my G35 and they suck compared to the Tanabe GF210s I just put on my girlfriend's 350Z. The Tanabes have a much more even drop and a much better ride.
kourosH's Avatar
kourosH
+2 also in for pix + impressions
Old Oct 19, 2006 | 01:43 PM
thirty5ounces
i think it looks really good though....you wouldnt recommend the stech? whats the price difference?
Old Oct 19, 2006 | 01:46 PM
SinCity350Z
Track Whore
They aren't bad springs, just not as good as the Tanabes. I think the Tanabes may be a tad cheaper too, but I don't really remember what I paid for the Tiens.
Old Mar 14, 2007 | 04:07 PM
shanecrosby's Avatar
shanecrosby
I want to see these pics too! can someone repost?
Old Mar 14, 2007 | 04:55 PM
Bob Martin's Avatar
Bob Martin
If ur gonna get tein springs get the S tech. Getting the H tech isnt even worth it seeing as how they barely have any drop. I have the S tech springs and I think they have a nice drop to them.
Old Mar 14, 2007 | 05:05 PM
black06z's Avatar
black06z
between the 2 springs, the S. Tech's definitely FTW!!!
Old Mar 14, 2007 | 05:09 PM
bofa's Avatar
bofa
I have the S.Techs on my 06. I liked them at first but after they settled the front ended up being a little too low and rubbed when turning and going over a bump at a certain angle.. not often just enough to aggravate me.
Old Mar 14, 2007 | 05:12 PM
shanecrosby
sending paypal to purchase the s techs tomorrow. I found a Z pic with them and you're right, they do have a nice drop.
Old Mar 14, 2007 | 05:14 PM
shanecrosby
I'll be running them with 19" rims. -specs in my sig. do you think I'll rub??
Old Mar 14, 2007 | 05:17 PM
redlude97's Avatar
redlude97
whats your definition of good? tanabe's are progressive while with peak springrates near stock, which means performance suffers for a better ride quality. Tein H-techs on the other hand are linear and stiffer than stock, while S-techs are progressive in the front, and also stiffer than stock. So other than the amount of drop they provide, what makes them better?
Tanabe GF210 Series 350Z progressive springs 1”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 336/375 (only peak rates are published, softer initial progressive rates unknown)
Stiffer then oem springs by F+7% R+10% (see note at very top)
Tanabe NF210 Series 350Z progressive springs 1.2”/1.2” drop on 350Z G35 drops will be higher
Spring rates in LBS 314/353
Stiffer then oem springs by F+0 R+3%
Tein H-tech 350z linear springs .3”/.2” drop on 350Z G35 drop will be higher
Spring rates in LBS 358/375
Stiffer then oem springs by F+14% R+11%
Tein S-tech 350z (fronts are progressive, rears are linear) .7”/.6” drop on 350Z G35 drops will be higher
Spring rates in lbs 386/402 (final rates only, softer initial front progressive rate unknown)
Stiffer then oem by F+23% R+16%
Jason@Performance
Dec 1, 2005 09:02 PM
