The big build has started :)
Old Dec 24, 2012 | 11:18 AM
  #381
Royal_T's Avatar
Royal_T
Amazing bro.. Looks so good..
Old Dec 25, 2012 | 12:02 AM
  #382
chad_everson's Avatar
chad_everson
Thanks!! Im hoping for a finish here soon.. but we shall see..
Old Dec 25, 2012 | 07:06 AM
  #383
JaE35z's Avatar
JaE35z
Great build!
Old Jan 1, 2013 | 07:03 PM
  #384
chad_everson
Thanks. Im hoping for it to be finished up soon and videos of it ACTUALLY running and driving!
Old Jan 1, 2013 | 07:28 PM
  #385
terrasmak's Avatar
Would love to see more pics and info on the Wilwood pedal box and install.
Old Jan 1, 2013 | 07:30 PM
  #386
chad_everson
What would you like to know?
Old Jan 1, 2013 | 07:43 PM
  #387
terrasmak's Avatar
Mostly mounting
Old Jan 2, 2013 | 11:28 AM
  #388
chad_everson
Ok, I will talk with the tech that fabricated the mounts for it and let you know. I know he didnt take pictures of the process when he made them though. Ill see on my next trip up there if I can get some more pictures of the mounts as they are now for you.
Old Jan 3, 2013 | 01:39 PM
  #389
Chebosto's Avatar
Chebosto
remove the hatch surface wing mount, and go through the hatch to a mount directly onto the frame.. the gt500 will produce enough downforce to crack the hatch unless you reinforce it underneath.....
Old Jan 3, 2013 | 05:52 PM
  #390
chad_everson
That mount is already in the process of being made. He already had that planned. They were doing an open house for the new shop and wanted it "together" to show it off. Once the mount is made and installed we will get pictures up for sure. Thanks for the heads up though !
Old Jan 8, 2013 | 05:06 PM
  #391
Jermy's Avatar
Jermy
this. a friend of mine has a time attack STi that he did that with his Kognition wing. didnt get many pics of it and i know our hatches arent even closely related to an sti but
Old Jan 8, 2013 | 06:58 PM
  #392
TAHorizon's Avatar
TAHorizon
^^^Kognition makes 350Z specific mounts:
http://www.kognitiondesign.com/#!models/c1p45
Old Jan 9, 2013 | 11:15 AM
  #393
chad_everson
Thanks for the pics / links for the wing bracket. Chris is almost finished with making it so we should be good to go for that.
Old Jan 9, 2013 | 11:18 AM
  #394
chad_everson
All that is left until the car is good to go is the following:
driver side window bracket made for lexan window
chassis harness made (so I can keep brake lights,turn signals etc etc
fuel lines ran
hydraulic e brake lines ran
install of 2nd brake calipers and brackets for hydraulic ebrake
mount made for the f1 mirrors to be mounted
labels on the fuse panel
after that all we need is tuning.
Old Jan 9, 2013 | 11:19 AM
  #395
chad_everson
Just curious..
What do you all think that I could sell the car for as it sits now?
How much could I sell the car for running?
List of parts on the car:
2003 Clean Title
Asuka Design Wide Body
Seibon Carbon Fiber Hood
Seibon Carbon Fiber Hatch
Seibon Carbon Fiber Doors
Shields Poly Carb Windows
APR F1 Side View Mirros
APR GTC-500 Rear Spoiler
Mastergrade Carbon Fiber Exterior A pillar
Mastergrade Carbon Fiber Exterior B pillar
Nissan OEM 2006+ HID Headlights
Nissan JDM 2006+ LED Tail Lights
Wilwood Superlite BBK
Wilwood Dynapro BBK
Wilwood Dynapro calipers x2 for hydraulic brake
Wilwood Pedal Assembly
Wilwood Brake Master Cylinders x3
ASD Verticle E-Brake Hyd.
RaceTech 4009 Seat x2
Buddy Club Seat Rails x2
RaceTech 6pt Harness x2
Sparco Steering Wheel
Sparco Weld On Hub
Custom CNC One Piece Solid Steering Shaft
Genissis Air Jacks w/ Stäubli JAC Airjack Lance w/ swivel
Aluminum Fuel Cell
Aeromotive Fuel Pump
Aeromotive FPR
ARP Wheel Studs
RacePak Data Logger IQ3
Haltech Platinum Pro 2000
DG5 True Coilovers Coilovers
Drive Shaft Shop Stage 5
SPL Upper Control Arms
SPL Rear Camber Arms
SPL Rear Traction Rods
SPL Rear Toe Links
SPL Eccentric Lockout Kits x2
SPL Rear End Links
SPL Front End Links
KPR Steering Angle Kit
Tein Inner Inner tie Rods
CCW C14 w/ BF Goodrich Tires
Eibach Sway Bar Kit Front / Rear
Carbonetics 1.5 LSD
Sikky lsx mount kit
SIKKY Headers
Sikky Diff Bushings
Sikky Subframe Bushings
LS1 Motor Set w/ spec stage 5 clutch and alum flywheel
Chase Bay Wire Harness w/ mil spec quick d/c
Full Chassis Harness
Red Top Optima Battery
C&R Radiator
FAL FAN
Tube Chassis Front and Rear
Roll Cage
Stitch Welded Entire Chassis
Chassis Media Blasting
Chassis Powder Coating
Full Paint
Switch Panel / Breaker Box
With labor and parts I have a little over 80k into the car without the price of car itself.
Last edited by chad_everson; Jan 9, 2013 at 11:25 AM. Reason: submitted before finished
Old Jan 9, 2013 | 03:00 PM
  #396
Barnabas's Avatar
Barnabas
National Z Club President
Prob be lucky to see 40k for it... if that.
I hate to say it but there is next to no resale in these cars once modded.
Old Jan 9, 2013 | 04:13 PM
  #397
chad_everson
I would be happy with 40k! Life has changed..priorities have changed.. getting married so time to move on I was thinking of putting it up for 35ish..
Old Jan 9, 2013 | 04:21 PM
  #398
ImWeeZzel's Avatar
ImWeeZzel
epic part out?
Old Jan 9, 2013 | 04:25 PM
  #399
chad_everson
wont be an epic part out.. It will just be a sale and will keep it together until it sells.. Or trade for an Hummer H1 wagon haha
Old Jan 9, 2013 | 04:39 PM
  #400
user 7373's Avatar
user 7373
30k is my guess part out would get you way more money
