FS: 27 inch PLC monitor 2560x1440 UHD led with speaker - $280 (Rockville)
Old Jan 3, 2014 | 07:43 PM
enuff4life's Avatar
enuff4life
Default 27 inch PLC monitor 2560x1440 UHD led with speaker - $280 (Rockville)
I've purchased 27" X-star 27in monitor back in september. It was great monitor for my photography work. However, I've moved to dell 30inch monitor so I don't need another monitor. It comes with power cord, and a dvi cable.
It is not just another 27inch monitor the resolution is up to 2560x1440 which is far better quality than regular 1080p monitors (1440>1080). You basically have more space than other same size monitors! The depth of black is far superior than other monitors. please just google why plc is better than other ips panels.
Here are quick specs
•2560x1440 High Resolution WQHD Panel / 43W Low power consumption.
•178 wide viewing angle / LED backlight / Bypass board
•Matte type screen / Piano-black high glossy slim bezel / TILT stand / Dual DVI-D
•Beautiful images with 50,000 levels contrast ration / 8ms Respond time
•5W+5W Built-in speaker / Space-efficiency using walls(100X100 VESA holes
Newegg and Amzon, sell this monitor around $350, but you can take it for $280!
you would need dual dvi graphic card which most current cards come with it. Laptops are not compatible with this.
I don't check here often, please email me back to
rawmagicvideo@gmail.com
or txt
301 502 13one7
Attached Thumbnails 27 inch PLC monitor 2560x1440 UHD led with speaker - 0 (Rockville)-61dozn3qb4l__sl1500_.jpg   27 inch PLC monitor 2560x1440 UHD led with speaker - 0 (Rockville)-97kgvleh.jpg   27 inch PLC monitor 2560x1440 UHD led with speaker - 0 (Rockville)-tne7fz3h.jpg
3vilbunny
Jul 18, 2017 05:10 PM
Tonyz_2004_350z
South East Marketplace
Oct 4, 2015 12:53 PM
350z82
Oct 1, 2015 06:25 PM
