Cutting carbonfiber(without fuking it up)
Old Oct 16, 2007 | 02:19 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Default Cutting carbonfiber(without fuking it up)
Hey guys i just bought a carbonfiber 350z engine cover for my g and i have to get it reshaped to fit the aps tall boy upper plenum i have.Anybody got some advice when using a dremel with carbon fiber.
Thanks,keith.
Old Oct 16, 2007 | 02:58 PM
turbokanji's Avatar
turbokanji
+1 on dremel and you'll be fine.... don't rush into things
Old Oct 16, 2007 | 03:22 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I wouldnt want to do that. Id imagine its fiberglass mixed with some CF, if so Id assume it would fray atthe ends when cut? Try shaping a very little piece and see what happens, good luck Keith.
Old Oct 16, 2007 | 03:32 PM
superchargedg
Damn Noobs
I was assured it was total carbon fiber,i guess we shall see when i try shaping it.
Old Oct 16, 2007 | 03:45 PM
Crom's Avatar
Crom
Dremel..and go slow..make sure your angle of cutting is always perpendicular to the surface...
Old Oct 17, 2007 | 07:42 AM
DROPPEDIT2WCE's Avatar
DROPPEDIT2WCE
The dremel is a horrid tool, I threw mine directly in the trash after one use. Weaksauce homeowner tool, you have access to air compressor's I'd assume, use a whizzer wheel and the appropriate disc from your Mac or Snap-on rep.
Old Oct 17, 2007 | 07:47 AM
mdracer76's Avatar
mdracer76
I've used Dremmel on CF before.. use high rotation speeds, and TAKE YOUR TIME. It will be fine.
Slow speeds on the dremmel can lead to the weave fraying, higher speeds prevent that.
Old Oct 17, 2007 | 08:08 AM
Driven1's Avatar
Driven1
Professional
+1 Keith just take your time and wear some sort of mask while your doing it b/c the resin is not to to breath in. I'd recommend taking a crayon or marker (although thats harder to remove if you mark it wrong) and marking the areas that need modification as well. Let us know how it goes.
Old Oct 17, 2007 | 08:14 AM
project.dwnshft's Avatar
project.dwnshft
used my dads dremel on med speed to cut and reshape my full CF eyelids....cut was so smooth and worked out perfectly
Old Oct 17, 2007 | 08:16 AM
Crimso's Avatar
Crimso
Default Abrasives.....
Garnet is no good (for wood only), aluminum oxide is OK, silicon carbide is good, diamond is best. And watch the heat buildup, you can burn the resin if you let the piece get too hot.
Old Oct 17, 2007 | 09:52 AM
DROPPEDIT2WCE
using a "whizzer wheel" (high speed air cut-off tool) will eliminate high/low setting nonsense as it is a much higher RPM tool, with less torque than a crappy dremel that is designed for nail salons and crafting wooden sculptures. Use painters tape/masking tape to off the area, then stencil the area that you will be cutting onto the tape and cut. This will also help avoid small cracks, chipping, and fraying.
Old Oct 17, 2007 | 01:41 PM
superchargedg
Damn Noobs
Thanks guys im gonna try it this weekend and hope it comes out ok.
Old Oct 17, 2007 | 02:47 PM
05Aucrarsx's Avatar
05Aucrarsx
supercharge G huh
still slow
Old Oct 17, 2007 | 03:06 PM
spacemn_spiff's Avatar
spacemn_spiff
Originally Posted by 05Aucrarsx
supercharge G huh
still slow
Slower than what, RSX or Civic - well they both are the same except for the skin? Troll.
Old Oct 17, 2007 | 03:09 PM
05Aucrarsx's Avatar
05Aucrarsx
rsx interior > *
Old Oct 17, 2007 | 03:12 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
dumb *** honda owner cant read a signature........hes got greddy twins. Hes put enough money into his engine to buy your car outright.
even if a rsx is faster, id rather have my z. Just something about seeing a bunch of 17yr olds pimping their rebadged honda fwd, 4cylinder pos that makes me laugh.
id be so nervous to cut the carbon fiber! Dremels definitely dont produce the smoothest looking cuts.
Old Oct 17, 2007 | 03:17 PM
05Aucrarsx's Avatar
05Aucrarsx
can't outrun ugly
05Aucrarsx's Avatar
05Aucrarsx
ahhh.....that was meant for the srt4 d-bags
Old Oct 17, 2007 | 03:32 PM
Fingers's Avatar
Fingers
+1 diamond is best and don't forget about safety, if you have a shop vac use it to suck up the carbon shards, that stuff is very bad for your body. In the military we use shop vacs and other types of suction tables to do all carbon work on, you should also have a resperator on. Carbon is what everything is made of and the human body can not break it down, it will get stored in the sacks around your heart and lungs.
Old Oct 17, 2007 | 03:36 PM
Cux350z's Avatar
Cux350z
hatersgonnahate
blasians mom ftw!
