Update AAM Built: Pun1sh3RZ w/AAM Twin Turbo Kit & STG II LB - 550whp/552wtq Pump Gas
Old Jul 18, 2008 | 09:26 AM
L. Baggins's Avatar
L. Baggins
Wow nice.
What's with the curve past 6000rpms?
Old Jul 18, 2008 | 09:27 AM
Driven1's Avatar
Driven1
Professional
Originally Posted by Jun
what spoiler is that?
The answer to your question is it's a Celica/Scion spoiler.
Old Jul 18, 2008 | 09:43 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Originally Posted by SC 350Z
so the first tune was at 13psi right? and second was at 17psi,for 5 psi a gain of 35whp, i thought the average gain per pound of boost was roughfly 10 to 15hp correct me were im wrong
Every car is different. Previously going from 13-15psi I was gaining 30whp per psi. My new set-up with much more agressive cams is much different.
Bryce is at the limit of pump gas, so the gains wont be as good there as from gains at lower boost levels.
What are these turbos good for?
Old Jul 18, 2008 | 09:50 AM
SC 350Z's Avatar
SC 350Z
Ahh i see thanks for suming it up bud i thoguht things looked like they were starting to get a little inefficent,anys nice bryce bet it runs good
Old Jul 18, 2008 | 10:45 AM
Clint@Altered's Avatar
Clint@Altered
Added a video.
+1 on What Alberto said.
The extra boost really added a lot of torque though - 70wtq!
We had some trouble with the car spinning at the torque peak on the dyno. The tire contact patch is relatively small and the tires are really do for a change. If you listen to the video, you can hear it squeal as it spins. This definitely contributed to some of the fall off. Frank and I hopped in the trunk to get the solid run where it made 550/550 and it was still spinning a bit - from the graph, the torque looks like it could be higher than it read.
We're also looking into the EVC parameters. New tires are coming soon anyway, we'll get it back on the dyno, hopefully sometime when its not 90+ degrees outside. LOL, it is July though
The compressor should be good efficiently to mid 20s. Its certainly not a "highway killer" type of kit, but with an upgraded fuel system, I really believe the car is capable of quick spooling 600s no sweat (although probably not on pump).
But not in the least am I or we unhappy with the 93 Octane numbers! The car feels GREAT
Old Jul 18, 2008 | 10:48 AM
Clint@Altered
Hold on, the video isn't working. I'm going to upload it again.
Old Jul 18, 2008 | 10:49 AM
Alberto's Avatar
Alberto
Cranky FI Owner
Compressor is good to mid 20's what about the turbine? If it spools so quick I doubt it would handle that.
BTW-no worries on the temps that what SAE correction is for. What were the actual numbers? Id imagine lower than SAE with those conditions.
Old Jul 18, 2008 | 11:12 AM
spddmn124's Avatar
spddmn124
you learn new things everyday. Thanks Alberto.
Old Jul 18, 2008 | 11:29 AM
Clint@Altered
Surprisingly, uncorrected was not that much lower somewhere in the low 540s for both. The dyno read 91 degrees with 38% humidity. The intercooler is certainly doing its job.
As far as the turbocharger goes, well that a secret lol . The quick spool is not necessarily a result of the turbine, a lot is from the over all
design of the system. The turbos are considerably bigger than for instance the JWT530, but produce similar spool characteristics with much higher overall outputs. They should be able to handle 23psi. Anything higher may be a bit much, but I've been pleasantly surprised thus far.
Old Jul 18, 2008 | 02:38 PM
tribal_visionz's Avatar
tribal_visionz
Does anyone know, but whats the max horsepower the Z can output using strictly pump gas? lets say..93 octane.
Old Jul 18, 2008 | 02:42 PM
superchargedg's Avatar
superchargedg
Damn Noobs
Sweet numbers Bryce and good job AAM.
Old Jul 18, 2008 | 05:10 PM
Alberto's Avatar
Alberto
Cranky FI Owner
Built, or stock? 3.5L? 3.8L? 4.2L? Waayyyyyy to many variables. Also what turbo kit?
Most 3.5L with off the shelf kits are mid 500's pump gas, some barely break 600's. Others are well into 600's on pump but I wouldnt know anything about that
Old Jul 18, 2008 | 05:45 PM
Eric the Ricer's Avatar
Eric the Ricer
That wasn't on the 3.5 was it??
Old Jul 18, 2008 | 08:20 PM
spddmn124's Avatar
spddmn124
Clint, I want to see the pictures of you and Frank/Jon sitting on the trunk of the car!!!
Old Jul 18, 2008 | 08:52 PM
Alberto's Avatar
Alberto
Cranky FI Owner
I have a 3.5L motor
Old Jul 18, 2008 | 08:55 PM
Eric the Ricer
And you were in to the 600's?? Info info!
Old Jul 19, 2008 | 01:15 PM
4SHIZZIL's Avatar
4SHIZZIL
I have a 3.5L motor
built 3.5
Old Jul 20, 2008 | 02:58 PM
  #38
Armando's Avatar
Armando
nice
Old Jul 21, 2008 | 06:29 AM
  #39
Floridaboy1605's Avatar
Floridaboy1605
Originally Posted by Clint@Altered
Thanks guys. The car feels insanely fast - tons of torque and it spools so damn quick - faster than the JWT530 kits. We're really happy with the numbers on 93 octane.
Plus the turbos still have A LOT left in them. C16...hmmmmm
(*Note: I had NOTHING to do with post deletion in this thread)
Can you explain why the power drops off so much?
Old Jul 21, 2008 | 06:57 AM
  #40
Clint@Altered
^ Check a couple of my previous posts (#25 & #29)
