how to remove tint?
Old Jul 21, 2008 | 08:49 AM
r0csfinest's Avatar
r0csfinest
Default how to remove tint?
is it something "easy" to do? or should i just take myself to the shop or get it removed?
Old Jul 21, 2008 | 08:53 AM
tribal_visionz's Avatar
tribal_visionz
im not sure, but i think you can scratch your windows up by trying to remove it. Certain films will last longer then the car lol
Old Jul 21, 2008 | 09:08 AM
Pun1sh3RZ's Avatar
Pun1sh3RZ
Had mine professionally removed, if you try it yourself and are unable to get it all off then you will be charged double to finish removing it since the glue is a b1tch
Old Jul 21, 2008 | 09:15 AM
Floridaboy1605's Avatar
Floridaboy1605
Real easy! Razor Blade under one edge and rip it off!! then use goo gone and get the glue off!
Old Jul 21, 2008 | 09:18 AM
10 TIL 4's Avatar
10 TIL 4
It's easy to remove. Just start at a corner and pull it up with a razor blade. The film itself comes off super easy but it's the clear adhesive part that takes a little bit.
Just use a spray bottle with soap/water mix and a fine edged scraper to get that off. You can have each window done in a few minutes a piece if you're careful. Windows with integrated defrosters can be a pain.......again, you just have to be careful.
Old Jul 21, 2008 | 09:20 AM
LAKERSFAN's Avatar
LAKERSFAN
very easy. just time consuming getting the adhesive off. they do sell a kit at pepboys but i found just some rubbing alcohol works pretty good to get the glue off.
Old Jul 21, 2008 | 09:25 AM
r0csfinest's Avatar
r0csfinest
do you know if the G has integrated defrosters?
Old Jul 21, 2008 | 09:55 AM
350Ricky's Avatar
350Ricky
I like Rice
damn, this makes a person think twice about getting tints =(.
Old Jul 21, 2008 | 10:28 AM
MR_X's Avatar
MR_X
rubbing alcohol, goo gone and razor blades did it for me. I have also used a torch and it work pretty well
Old Jul 21, 2008 | 10:36 AM
r0csfinest's Avatar
r0csfinest
just dont be an idiot like me and get 10%
Old Jul 21, 2008 | 10:43 AM
jubes's Avatar
jubes
watch when using a razor... I did this method, and ended up scratching my passenger side window... now I can see fine scratches that can't be removed. And a whole new window is $400+ which sucks *****...
Just do it professionally...
Old Jul 21, 2008 | 10:46 AM
sbZenth's Avatar
sbZenth
yeah i was gonna suggest light use of a torch.
Old Jul 21, 2008 | 10:47 AM
citymunky's Avatar
citymunky
Only the rear window.
Old Jul 21, 2008 | 01:41 PM
terps's Avatar
terps
apparently this stuff called new glass or something similar helps with scratches in the glass. its work a shot. my friend swears by it
Old Jul 21, 2008 | 07:58 PM
tribal_visionz
and what about the tiny centimeters of film below the door panels? what if you cant reach it, idk!! just some thoughts..
Old Jul 22, 2008 | 01:39 PM
r0csfinest's Avatar
r0csfinest
well... just did it myself. took about a hr without doing the back window. going to take it to the shop to do the back window
Old Jul 23, 2008 | 12:51 PM
NIZZMO's Avatar
NIZZMO
^^^Can you get a ticket for having tint on the back glass in MD ?
Old Jul 23, 2008 | 01:30 PM
Driven1's Avatar
Driven1
Professional
It's summertime so Im going to give you guys a little secret I used to use in FL.
Side windows are peel and scrape. Just keep a fresh blade and you wont scratch the windows.
This is for the back windows with defrosters.
1. Take a black trash bag and cut it (a little big) to the shape of the rear window.
2.Take 409 (other cleaners with high alchohol content work well too) and spray the back window (inside). I mean soak the crap out of it. Lay towels if preffered to not completely soak your rear deck.
3. Take the black trash bag and lay it against the inside of the glass, using the solvent to "stick" it to the window. It doesn't have to be perfect... bubbles are ok...just make sure it stays on the window for the most part.
4. Now go park the car directly in the sun for 15-20mins. Repeat the process 3-5 times. Pull bag the bag, soak it, and put it back. You should be able to see it bubbling with most films after some time.
After repeating a few times just start in a corner and peel. Most of the glue will come right off with the film. If it doesn't what little is left can be quickly removed with a little piece of scrub pad and soapy water.
Old Jul 23, 2008 | 01:53 PM
Eric the Ricer's Avatar
Eric the Ricer
That's why you're the man Robbie
Old Jul 23, 2008 | 02:09 PM
spddmn124's Avatar
spddmn124
great info!!! thanks!!!
