Guys i need help(desperate)
Old Sep 7, 2008 | 06:36 AM
superchargedg's Avatar
superchargedg
Damn Noobs
Default Guys i need help(desperate)
I screwed up while i was repairing an electrical wire in the main harness that runs across the front of the motor.I was an idiot and didnt disconnect the battery and one end grounded out and now the engine wont start.
It cranks normally but im not getting any power to my HKSII(no red light is on).I checked all the fuses and they check out good....also with the key in the run position the electric fans stay on all the time.
Anybody have any suggestions were else to look.
Old Sep 7, 2008 | 06:39 AM
.steeeeZ33.'s Avatar
.steeeeZ33.
@ J&D auto
only thing relaly maybe use a digital multimeter and find the dead wire and replace/fix from there....
Old Sep 7, 2008 | 06:40 AM
Jarred@Z1's Avatar
Jarred@Z1
Z1 Motorsports
o noes sounds like its in fail safe with the fans running check the fuseable links that are on the positive terminal on the battery.
Old Sep 7, 2008 | 06:43 AM
superchargedg
Damn Noobs
They all looked ok as i could not see a burnt one.
Old Sep 7, 2008 | 09:41 AM
Chugg's Avatar
Chugg
did you check all 3 fuse boxes? the one under by your feet the one above the battery and the one in the big black box behind the batt?
Old Sep 7, 2008 | 09:59 AM
superchargedg
Damn Noobs
Yep and i think i probably fried the ignition relay.
Old Sep 7, 2008 | 10:02 AM
spddmn124's Avatar
spddmn124
Its probably the ignition fuse.. I didi the same thing with EDFC install... $40 dollar fuse... WTF.
Old Sep 7, 2008 | 10:09 AM
superchargedg
Damn Noobs
Were is that fuse located....is it behind the battery?
Old Sep 7, 2008 | 10:11 AM
spddmn124's Avatar
spddmn124
yeah, its the one underneath the battery cover.... its sucks becasue it incorporated 3 fusese(2 ABS and, 1 ING. fuse into one), Nissan sucks, its cost me $40.
Old Sep 7, 2008 | 10:44 AM
superchargedg
Damn Noobs
Thanks.Did your car crank but not start or did it do nothing at all cause mine cranks but have no power to the ignition.
Old Sep 7, 2008 | 06:57 PM
spddmn124's Avatar
spddmn124
I am not sure, sorry... check the fuse, its really obvious, you know better than I do Keith. lol
Old Sep 7, 2008 | 09:19 PM
z2g's Avatar
z2g
my friend sort of did the same thing with his car and sometimes it would start and sometimes it wouldnt/ when it would start it would run like $hit and couldnt idle and eventually die out and wouldnt start again. Ended up being that it fried the computer. Luckily they still covered it under warranty for him
Old Sep 8, 2008 | 06:22 AM
108NismoZ's Avatar
108NismoZ
I Have A Picture Of Where The Ignition Relay Is If You Want Me To Email It To You Pm Your Email
Old Sep 8, 2008 | 07:13 AM
abui01's Avatar
abui01
I heard this stuff happens when there's too much rice on a vehicle... is that true?
Old Sep 8, 2008 | 07:19 AM
4SHIZZIL's Avatar
4SHIZZIL
call dave at FT... I dont know how he does it...but he can get a factory ECU for a bit more than that fuse if you order him a lap dance...lol
Good luck Keith call me if you need a delivery boy after you talk to dave....thinking of heading to Elite this week anyways....let me know...Pming my cell to ya.
Old Sep 8, 2008 | 02:19 PM
superchargedg
Damn Noobs
I found it after using one of my techs multi meters.It was the right upper 10amp fuse in the fuse block behind the battery.After using the multi meter i found the blown fuse and pulled it out but still had a hard time seeing were it blew.It was just a real tiny little mark on it that i just could barely see.
Thanks for the help.
Old Sep 8, 2008 | 03:34 PM
spddmn124's Avatar
spddmn124
nice, what was the fuse for?
Old Sep 8, 2008 | 03:41 PM
superchargedg
Damn Noobs
I dont know and dont care as it was the first fuse i tested with the multi meter and it was a dead fuse.I put in another fuse and she started right up.
Old Sep 8, 2008 | 05:40 PM
.steeeeZ33.
@ J&D auto
w00t it was probably the ECU fuse.. ricky's went out on his car and all it would do was crank.
Old Sep 9, 2008 | 08:17 AM
350Ricky's Avatar
350Ricky
I like Rice
yea, my ecu fuse went.
My car would still crank.
A/C fan was still on when car was on position.
Sorry I didnt post earlier Keith, I saw that you said that all your fuses checked out good so I figured it wouldve been useless info if I posted.
