Trading built motor
Old Oct 24, 2008 | 11:09 AM
ILLBZNU's Avatar
ILLBZNU
Default Trading built motor
WHY I AM SELLING IT:
I have not had sucess selling the car as a whole, so I am parting it out.
I have a 2 month old baby girl which caused me to need an SUV instead of the Z.
The Motor is a 2003 and has 3,700 miles on it and only 300 of those with a turbonetics setup on it. I gave up on going the turbonetics route
$3,000 plus your stock motor
THIS PRICE INCLUDES THE MOTORS BEING SWAPPED AT A SHOP IN Southern MD.
· Built by Bob Hamilton in Delaware (using the most up to date machining equipment available and on display at the 2006 SEMA show).
The block and head was redecked.
Block and head oil passages were cleaned.
The crank journals were polished and the crank was balanced.
New valve stem and cam seals were installed.
Valve stem heights were set.
All new timming assembly was added.
The cold clearance was set.
· Arias Extreme Duty 9:1 pistons
· Pauter Rods
· Nismo High Flow oil pump
· ½” ARP head studs (Block and head was CNC machine honed and drilled, not from template which is commonly done)
· Coolant bypass modification (allows extra coolant to the back side of cylinders utilizing the OEM Pathfinder coolant duct.)
· 5 angle valve job
· Heads were ported and polished
Old Oct 24, 2008 | 11:52 AM
Z_Nick_Z's Avatar
Z_Nick_Z
PM sent
Old Oct 24, 2008 | 07:53 PM
txshldm's Avatar
txshldm
B8BB8B88
hey man i might be interested and im in southern md. pm me maybe we can meet up sometime to check it out
Old Oct 25, 2008 | 05:26 AM
ILLBZNU's Avatar
ILLBZNU
Default Seriously interested?
Anybody that is Seriously interested just call me at 540-775-1388
Old Oct 25, 2008 | 07:06 AM
citymunky's Avatar
citymunky
Buy a G35 sedan, swap the motor and sell the Z when you are done.
Fixxxercask
Nov 9, 2015 11:10 AM
