question
Old Jan 8, 2009 | 04:34 PM
meow69's Avatar
meow69
Default question
About a week ago everytime I press on the gas pedal when Iam in Idle/stop. I can hear water making a bubbling noise from the engine... Any ideas on what I should look for. Only mod is a jwt popcharger.
Thanks
Old Jan 8, 2009 | 04:59 PM
350Ricky's Avatar
350Ricky
I like Rice
Is it still happening up till now? or was it happening a week ago?
Old Jan 8, 2009 | 05:04 PM
Eric the Ricer's Avatar
Eric the Ricer
Your hamster is running out of water
Old Jan 8, 2009 | 07:26 PM
meow69's Avatar
meow69
its still happening
Old Jan 8, 2009 | 08:22 PM
PhiSig's Avatar
PhiSig
Wheel Whore
Might wanna start with checking fluid levels????
Old Jan 8, 2009 | 08:43 PM
abui01's Avatar
abui01
My car makes bubbling noises when I shut it off... for the next 20 mins too. Kinda sounds like a snake crawling through your engine bay, but I think it's hella cool. Not sure about bubbling noises when idle though, doesn't sound too serious.
Old Jan 9, 2009 | 05:05 AM
NX2KDET's Avatar
NX2KDET
Cpt. Nauti Raw
My power steering fluid resevoir bubbles sometimes.
Old Jan 9, 2009 | 05:56 AM
ZRuggernDC's Avatar
ZRuggernDC
Yep, same here.. Freaked me out at first. But, its no big deal.
Old Jan 9, 2009 | 05:53 PM
meow69's Avatar
meow69
thanks for the responses..
Old Jan 9, 2009 | 05:56 PM
surfcity40's Avatar
surfcity40
certainly it isn't hydrolocked or there'd be no "gurgling", there'd just be nothing.
The gurgling could be bad gas? as in bad gas? sry, i'm not more help.
Old Jan 9, 2009 | 06:52 PM
usgpru27's Avatar
usgpru27
did you have the AC or the Defoggers on.. Sounds like gas in the HVAC system...
Old Jan 9, 2009 | 07:44 PM
350Ricky's Avatar
350Ricky
I like Rice
Do you have A/C or Heater on when you hear the noise?
Old Jan 11, 2009 | 04:03 PM
meow69's Avatar
meow69
No I do not. I just start the car and press the gas and can hear some water somewhere in the engine ... even when iam reversing I can hear it when i blip the throttle
Old Jan 11, 2009 | 04:06 PM
surfcity40's Avatar
surfcity40
no you can't. it's your imagination. you can't hear water.
Old Jan 11, 2009 | 04:41 PM
halfass872's Avatar
halfass872
My cavlier (beater) does the same thing. Everythign seems fine under the hood. I fear it may be a head gasket leaking "compression" into my cooling system. But it's rare and there's no certain time it seems to do it. (hot, cold, turning, etc.) And none of my fluids are missing or an odd color.
So i think it's nothing to be worried about.
Old Jan 11, 2009 | 05:35 PM
NIZZMO's Avatar
NIZZMO
Sounds like air in the cooling system, check to se if thats it, next time before you start your car take off the raid.cap start the car and let the thermostat warm up then top off
with antifreeze and put the cap back on ,if thats not it then your heater core may be clogged if thats the case reverse fulsh it. All I can think of without hearing it for myself. GL
issyz
Jul 2, 2017 03:04 PM
Alexreyes
Sep 30, 2015 11:30 PM
Conway_160
Drag
Sep 29, 2015 08:07 AM
