Rolling Fenders on a 300zx HELP!!
Old Jan 21, 2010 | 05:03 AM
seven0thr33's Avatar
seven0thr33
Question Rolling Fenders on a 300zx HELP!!
Does anybody around Northern Virginia Area, or DMV offer fender rolling service or know of a place that does it?
Old Jan 21, 2010 | 05:04 AM
lek at ngc's Avatar
lek at ngc
elite importz
Old Jan 21, 2010 | 05:43 AM
JDMITR22's Avatar
JDMITR22
We do them! we are in rockville, give me a call 301 424 6577
we can fit u in today
-RJ
Old Jan 21, 2010 | 06:56 AM
NNOCENT's Avatar
NNOCENT
Elite Importz.
Call Chris Yi
Old Jan 21, 2010 | 07:01 AM
WYZIWYG's Avatar
WYZIWYG
-RJ
Just checked your site out. Might have to pop in for an estimate soon....
Old Jan 21, 2010 | 07:07 AM
JDMITR22's Avatar
JDMITR22
^sounds good! come in anytime!
Old Jan 21, 2010 | 07:09 AM
scotts300's Avatar
scotts300
Why? What size/offset wheels and what size tires are you trying to put on? You can't roll the front, at least not that much, and you're better off to TRIM the rear fender lip of a 300ZX than roll it. I've seen a few fenders buckle when rolled. With the right set-up, you can fit large tires assuming that's your goal. I have 285s on the front of my 300ZX with no fender modification, and a 295 in the rear with the fender lip trimmed just a few mm.
Again - I'd avoid rolling.
Old Jan 21, 2010 | 07:19 AM
JDMITR22's Avatar
JDMITR22
^we can do either, we have rolled 300zx rears before with no issues of buckling.
trimming is going to be best for clearance.
Old Jan 21, 2010 | 09:29 AM
Chen's Avatar
Chen
Dead blow hammer?
Old Jan 21, 2010 | 08:24 PM
seven0thr33
Im actually running
18x8.5 +35 235/40/18 (f)
18x9.5 +22 265/35/18 (r)
my front is rubbing, or atleast I think, when I turn my steering wheel all the way and Im not sure about the back. Im afraid that the back might rub over bumps and potholes. Not really sure what to do, whats your advice?? sorry kinda new to this wheel thing heres a link of my car with those wheels, and again, what should I do?? thanks.
https://my350z.com/forum/other-vehic...the-300zx.html
Old Jan 21, 2010 | 09:56 PM
scotts300's Avatar
scotts300
Im actually running
Hmm. I doubt the front is rubbing. That is a tall sidewall, but it's nothing that hasn't been done before (I ran 255/40 on an 18x9 for years). That's a pretty mild wheel, offset, and tire size on your fronts. . . . My $ is on the back, as that offset is for 350Zs not 300ZXs. If you want to run that rear wheel without rubbing, I suppose I'd first try trimming the fender (dremel - sounds like JDMIT can do this at their shop), but it may not be enough. You may need to get a much smaller tire. Typical offset is in mid 30s for a 9.5" wheel. My 10.5" rears are +43, which is the same as a 9.5" wheel with a +31 offset, and my fenders are trimmed (big tires though). With a good trim and some camber, you may be able to pull it offer with that tire.
Your Z looks good otherwise - mine is black as well.
Old Jan 23, 2010 | 10:35 AM
seven0thr33
Thanks! I really want to run wide tires in the back, I was hoping to run 295 or around there. How will the car look after the fenders are trimmed? so you wouldn't recommend fender rolling and a few degrees of negative camber? I don't think they're rubbing right now but Im planning on lowering it. whats your suggestion on lowering it?
Old Jan 23, 2010 | 10:38 AM
seven0thr33
sounds like I might have to go with trimming, but I dont know how the car will look after trimming. Where are you guys located at?
Old Jan 23, 2010 | 10:51 AM
JDMITR22's Avatar
JDMITR22
^you really wont notice a diff from the outside with trimming
we are are :
801 E Gude Drive
Rockville, MD 20850
Old Jan 23, 2010 | 12:08 PM
scotts300's Avatar
scotts300
we are are :
801 E Gude Drive
Rockville, MD 20850
Correct, can't even tell my fenders are trimmed.
Seven - if you want to run a 295, you should have a 10" tire. You can do it on your 9.5, but the tire will look a little bowed. You could run a 285/30, which is nice b/c it's the same total height as the stock 300ZX TT rear tire, or a 285/35 to fill the gap a little bit. I'm only lowered on Eibach springs, so 0.8" drop.
Here is mine currently with the 285/30/18s and the same 0.8" drop. You can see a little bit of gap in the back. Those are 285/30/18s on the front as well.
I am going to switch next weekend to a 295/30/18 R888 tire for a little more footprint and to pick up some of that gap.
and here is the old set-up with 295/35/18 drag radials:
Old Jan 23, 2010 | 12:31 PM
seven0thr33
we are are :
801 E Gude Drive
Rockville, MD 20850
guess I'll have to pay you guys a visit this week, should I just call or bring the car over for you guys to take a look at?
wow your z is BEAUTIFUL! love those wheels and wide tires! thanks for the info, I'll probably just follow your advice. By the way, how dark is your tint?
Old Jan 23, 2010 | 12:57 PM
JDMITR22's Avatar
JDMITR22
^Yupp just come by! Some us the guys are packing up our trailer and goin to Sno*Drift Rally 2010 on wednesday, so Monday or Tuesday are better!
Old Jan 23, 2010 | 05:37 PM
scotts300's Avatar
scotts300
Thanks, it does ok!
Tint is dark on the back 3, I think it's 5%, but lighter on the sides, like 25% so that I can see out of them.
Old Jan 24, 2010 | 11:27 AM
amg55driver's Avatar
amg55driver
chris for sure,
Elite importz.
he rolled all my cars..
bentley, porsches, evo x , 350z, even jaguar...
Old Jan 24, 2010 | 02:14 PM
JDMITR22's Avatar
JDMITR22
^Chris is my boy so i cant knock him!
both our shops do it and have experience in a WIDE range of cars from civics to exotics.
