wanna try autocross??? OCT 9th
Old Oct 11, 2010 | 01:13 PM
  #201
bigcloud's Avatar
bigcloud
Originally Posted by Barnabas
Mike what do I need to do to help combat my severe understeer?? I loves it and def want to get the car to where it will be more competitive next time.
Barnabas I had massive understeer when I first started. My track rims were 225/35/19 Front and 245/40/18 on the rear. I know bad choice. They were the only set of decent tires I had. Sooo I ended up getting new tires for my front set of 18's...which put me a 245/40/18 SQUARE on the front and rear. Made a world of difference in understeering. Plus what Mike said about tapping the brakes before a turn shifts the weight to the front. I do that as well and I have pretty good results.
  #202
03threefiftyz's Avatar
03threefiftyz
First off I wouldn't use the dampers at full stiff. Just as an FYI my rears are 5 (out of 12) clicks (12 being the stiffest) for compression and rebound is only 6 out of 12. Fronts are 8 clicks for compression and (1 3/4 turns out of 2.5) for rebound. I bump it up to 2 full turns on slalom heavy course though.
It is going to be impossible for you to null out the understeer though until you commit to a larger front tire. That big stagger you are using is the primary problem.
My set-up is *** backwards to what you would want with that stagger, but I have almost no understeer. I turn the wheel and goes in that direction......hard.
Old Oct 11, 2010 | 01:16 PM
  #203
Barnabas's Avatar
Barnabas
National Z Club President
ok well I will soften up for next time and wait it out till the next set of tires... once I get the bigger tires then I will dial in the suspension straight into it.
Old Oct 11, 2010 | 01:30 PM
  #204
03threefiftyz
I would soften the dampers some and move the front bar to either the second stiffest or full stiff. This might seem counter-intuitive, but it will lessen the roll and make the turn in a bit more direct....
Old Oct 11, 2010 | 01:46 PM
  #205
Barnabas's Avatar
Barnabas
will def do that
EnjukuRacing
Sep 30, 2015 06:55 AM
sherm
Sep 10, 2015 11:02 PM
