Motorsports The Z in its Natural Habitat
Helmet not Fitting in Car
Old Mar 21, 2003 | 07:35 PM
  #41
jackwhale's Avatar
jackwhale
Hi Dolph: Actually you were one of the guys I was going to talk with at the Stick this weekend. I guess you answered the question we have been talking about. Must take a couple of seconds off your time.
Kevin is also over 6', we might see what he does.
I guess it is supposed to rain on Sunday? That will make everyone's tires handle the same.
Old Mar 21, 2003 | 07:45 PM
  #42
MannishBoy's Avatar
MannishBoy
I do have to also move the steering wheel up a bit for the old knees when I've slid up a bit I typically like my wheel fairly low (pointing toward the center of my chest, or maybe slightly lower), but the way this car sits it isn't that bad a bit higher.
The Simpson helmets were a bit more comfortable, but for the extra $50 (found a local shop selling the LX N for right at $200 and the Voyager N for under $300...excellent prices compared to online), I didn't really care that much as little as I'll use it. I might try to find a Bell to see how that one fits if I get a chance.
Old Mar 21, 2003 | 09:45 PM
  #43
GaryM05's Avatar
GaryM05
Default Re: Snell
Originally posted by zPilott
the main difference being that SA rated helmets provide fire protection, whereas M rated helmets do not need to (reading through the standard, the other differences seem pretty minor). A lot of companies actually make both an SA and an M rated version of the same helmet, the only difference being the liner material (the SA will have a flame retardant liner) I couldn't find any helmets that actually held both ratings though, so I don't know what that is about...I was hoping to be able to find something that would be sufficient for both, and I believe an SA rated helmet will do that, but if the even you are at requires an M rated helmet, you probably won't have an easy time convincing the organizers that the SA will do.
You're right, the SA helmets are fire-resistant, whereas the M are not. The other difference between the 2 ratings is that the SA helmets are built to withstand multiple impacts within the context of the same crash (such as during a rollover accident in a car,) while the M is only designed to withstand a single impact. From this and from most folks I've talked to, the SA helmet can be used for M events, but not necessarily vice-versa.
Gary
Old Mar 25, 2003 | 06:47 AM
  #44
jackwhale's Avatar
jackwhale
I poled two other 350 drivers at the autocross this weekend. Both of the other drivers over 6' 1" mentioned that their helmets touch the ceiling. I still can put 2 fingers between my helmet and the roof of the car. I must be mis-shapen in some way.
Old Mar 25, 2003 | 09:26 AM
  #45
zPilott's Avatar
zPilott
I checked later, and I have about two fingers with my helmet off....
OdesiTT
Sep 30, 2015 10:47 AM
lolsupfoo
Sep 9, 2015 12:57 PM
ILoveDrifting
Sep 7, 2015 03:15 PM
