Most rwhp NA build
Old Jul 24, 2008 | 05:55 AM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
see
so, is it possible? sure, anything is possible. Is it likely? Nope
rednezz post your latest sheet...congrats on the new #'s!!!!
Old Jul 24, 2008 | 06:06 AM
Chef-J's Avatar
Chef-J
Booooosstt!!
Old Jul 25, 2008 | 05:45 AM
shakuya88's Avatar
shakuya88
Hmm, so my level 1 goal should be scaled down a bit since 300 is "impossible" on DE. I'm at 235 base line. With bolt ons and no cam new goal is 260 at wheels. I'm going to built it eventually, I just wanted to get all I could out of it as it...not as much as I had hoped.
Old Jul 25, 2008 | 07:12 AM
KA24DE's Avatar
KA24DE
If you think the VQ is maxed out at the Specific output of only 85hp/liter, you are mistaken.
You will need to make the car breathe. I estimate, without opening the motor, you can bolt on, and tune around 260-270whp, with the right combo of parts, that have to work as a team. Cams, headwork and more tuning could easily lead to 300whp.
JWT added 15whp from a camswap alone, Having a device that can tune cam angle, and a good intake manifold can gain on that. And Some slight headwork couldn't hurt.
If you break it down, and think about it, it doesn't have to be too costly.
Old Jul 25, 2008 | 07:16 AM
KA24DE's Avatar
KA24DE
I just looked back and read this thread. Looks like my estimates are spot on. I could put together a small part list if it was wanted. But I have to admit, I am no tuner, and I can only estimate.
Z1 Performance
Former Sponsor
it's not impossible at all, it's just not likely without cams (expensive), headwork (which is expensive for proper work), headers (also expensive for proper ones), tuning, etc. The building of the shortblock is not all that costly when it comes down to it...its everything else that makes it an expensive proposition
260 whp with bolt ons and tuning is quite easy to achieve
Old Jul 25, 2008 | 07:22 AM
KA24DE's Avatar
KA24DE
Originally Posted by Z1 Performance
it's not impossible at all, it's just not likely without cams, headwork (which is expensive for proper work), headers (also expensive for proper ones), tuning, etc. The building of the block is not all that costly when it comes down to it...its everything else that makes it an expensive proposition
For a nice porting job, and cleaning up the quench areas on the VQ head, would cost about how much? Do you belive that it is worth tha gains to be had?
The VQ Needs a true high rpm manifold, and maybe adapting the Maxima's Varible manifold could do the trick. You'd also need to upgrade the oil pump, and have cams that can push the peak into the higher RPM region.
Old Jul 25, 2008 | 07:25 AM
Z1 Performance
Former Sponsor
you would have to ask someone who does headwork for a living. That is like asking "how much is it to paint your car". Lots of places claim to do headwork, not so many do work that is worth paying for. A proper valvejob yields big time gains, and is expensive, and so is proper porting. Headwork is, and should be, the most expensive part of a full motor build as it's the most critical aspect to making broad torque, and hp gains vs stock. The power of the engine is in the heads as we all know
The intake manifold is certainly a part of the equation, but the intake, cams, and header all need to be matched to work well with one another to achieve meaningful results
Old Jul 25, 2008 | 07:28 AM
KA24DE's Avatar
KA24DE
Agreed. Z1 doesn't provide head machining? I don't know, which is why I asked.
But, If you remember a while back, the VQ30 Maxima with JDM VQ35 cams (Near JWT specs they said), and a Piggyback unit was able to achive 270whp. With more displacement, a better head, and VVT, the VQ35 could have a broader powerband, and more peak power.
Old Jul 25, 2008 | 07:30 AM
KA24DE's Avatar
KA24DE
Refresher:
VQ30DE-K Swap
VQ35 Oil pump w/ low pressure cut off switch
VQ35 JDM cams (similar specs to JWT S1)
VQ35HR valve springs and retainers, double shimmed
Mild head "work" (NOT ported though)
Unorthodox flywheel
Exedy Stage 1 clutch
Greddy EManage Ultimate
Pathfinder TB
Stock DEK crank pulley
Custom intake w/ MAF delete
Cattman headers/y-pipe/catback (plus cutout)
Low temp T-stat
Walbro fuel pump
Returnless fuel rail w/ adjustable FPR
The VQ needs a true high rpm manfold first.
Old Jul 25, 2008 | 07:33 AM
Z1 Performance
Former Sponsor
we only work on our own in house stuff, we don't offer any labor services here, strictly parts
KA24DE's Avatar
KA24DE
"So it goes without saying I'm happy with that. Interestingly enough, the modeling I'd done before building the engine predicted around 275 whp at 7700 rpm, and I was skeptical at the time that it was accurate (never fully trust software lol), but hey the program was just about bang on. It does require meticulously measuring and inputing data to get that close though.
So below I've posted 2 graphs, the first one is the best run from today, and the second is just a fun comparison with my 220whp run from 2005 (with stock DE cams and 00VI). The cams have obviously shifted the power band as one would expect, although I have changed more than just cams between the 2005 dyno to now."
Old Jul 25, 2008 | 07:36 AM
KA24DE's Avatar
KA24DE
You know, Z1 would be my hero if the made a manifold like a DE-K's but promoted just a tad less high power tradeoff for some more power below 5000rpm. That way if would still feel powerful in DD, but kick but in the 5-7500/8000rpm region.
Easier said than done.
Old Jul 25, 2008 | 07:53 AM
Z1 Performance
Former Sponsor
we have an intake manifold solution we're getting ready to work on for my car, but I'm not making any predictions on power, etc until all testing has been done. I am all about higher rpm power an increasing the torque curve, so that is what I personally am searching for. I was looking forward to trying out, and even playing with, the Cosworth manifold, I just got tired of waiting, so we did something else instead.
sorry, no hints either
Old Jul 25, 2008 | 08:00 AM
KA24DE's Avatar
KA24DE
Not cool .
Good luck.
Old Jul 25, 2008 | 09:18 AM
__jb's Avatar
__jb
Z + Rear Seat
I would love to see how a Cosworth manifold works on your Z.
What's the deal with them? I hear they changed the manufacturing process to help stop the end panels from leaking. Have they been discontinued or are we just waiting again?
That's no fun...
Old Jul 25, 2008 | 09:38 AM
Z1 Performance
Former Sponsor
jb - I wish I knew what the situation was, I honestly have given up asking and am taking the zen approach to it now
Old Jul 25, 2008 | 02:02 PM
  #38
OCG35's Avatar
OCG35
Kudos for "Getting it"!!!... I've tried to relay similar to people and man - it just goes so far past them - its like I'm speaking quantum physics or something... so many people want to just ignore common logic and go pages and pages about one bolt on vs stock... without understanding how the sum of all else that has been done effects the results.
And slapping on a SC or ST or TT to get power just isn’t as satisfying to me... kinda the easy way out (maybe the economically sound way, but not as gratifying to me).
Old Jul 25, 2008 | 02:28 PM
  #39
__jb's Avatar
__jb
Z + Rear Seat
Several people with very powerful NA VQ engines have already posted in this thread. If you read their build threads you will see that they are well designed, integrated builds.
No quantum physics, just hard work. The NA VQ path is much less traveled than the FI path. It's a lot less documented and much more difficult to get everything working together.
Old Jul 25, 2008 | 02:32 PM
  #40
OCG35's Avatar
OCG35
I wasn’t referencing this thread... this thread is a very intriguing read! Lots of good info!
I meant in general - most people don’t understand that it’s a combination of breather mods and moderate to wild engine work that result in performance.
To often people want to say one component is worthless and is no better then stock - even when it comes to cams and headers... rarely do people research or take the time (or even trial and error) to find the right combination of things that actually do work.
