NA Build: Kacz07's 2006 SS 350z RevUP
Old Nov 8, 2010 | 09:33 PM
  #221
kacz07's Avatar
kacz07
I am looking into a slight issue with the low rpm cruising. With a little gas, the car gurgles and bogs til it reaches 3500rpms (correlates directly with torque curve). I think this could be related to the MAF housing being too large and the airflow coming from a restrictive 72mm stock airbox, too, just not enough airflow and what does come is swirling right in front of the MAF sensor.
If anyone has any anecdotal offerings in regards to their driveability in the low rpms, it would be helpful and informative for
anyone following along.
Before I acquired the larger MAF housing, I placed an order with GTM for a 3" MAF. Interestingly enough, the part just came due last week and I'll see if those problems can iron themselves with their housing, which is smaller than the current stuff. Also, 1cockyz has talked about the mustang guys having the same MAF sensor and it's irritability with housings larger than 75mm, mentioned previously in this thread. Mind you, these cars can make much more than 300whp with this housing.
BTW, thanks for the awesome posts, Sasha! Interested to see the shift in torque pulses with a more suitable header for my setup.
Old Nov 8, 2010 | 10:31 PM
  #222
kacz07's Avatar
kacz07
I'm also wondering if the driveability could be improved by increasing the idle to 1500-2000rpm. The extra air velocity at idle might help, no?
Old Nov 9, 2010 | 03:32 AM
  #223
Dr. Venture's Avatar
Dr. Venture
why don't you just test the theory and remove the box completely and go for a drive.
Old Nov 9, 2010 | 07:34 AM
  #224
kgkeen101's Avatar
kgkeen101
You probably just need some mid range tuning done on the street or dyno.
Old Nov 15, 2010 | 02:22 PM
  #225
kacz07's Avatar
kacz07
Bump for SG headers being completde in the next few weeks!
Old Nov 16, 2010 | 05:54 AM
  #226
SGSash's Avatar
SGSash
Vendor - Former Vendor
Check if the AFRs are wavering between lean and rich with the O2 sensors un-plugged (to eliminate O2 FB). If the AFRs are steady (which I am sure they won't be), then I would try a few things:
Play with cam timing, reduce overlap if possible (full retard on intake, advance the exhaust)
Reduce ignition timing, which may help reduce the surging just by making the engine a bit lazier, requiring a bit more throttle, hopefully smoothing things out.
Looking forward to seeing your results with some real headers!
Old Nov 16, 2010 | 10:01 AM
  #227
kacz07's Avatar
kacz07
Thanks for the tips, Sasha. I will share with RT when I bring the car back to them in the next few weeks.
For anyone interested, a quick vid of engine bay at idle:
Keep in mind, I do have motor mounts, so I expect a little more noise than usual. I appreciate any comments.
Old Nov 16, 2010 | 10:06 AM
  #228
Dr. Venture
every time we go somewhere and get out. i am going to yell out..."NOOOOOOOS" and run away.
Old Nov 16, 2010 | 09:06 PM
  #229
kacz07's Avatar
kacz07
^Haha. Make sure you bring your megaphone.
Old Nov 16, 2010 | 09:15 PM
  #230
kacz07's Avatar
kacz07
Now that the Brembos are installed, I'm looking to upgrade the suspension, which is probably the first thing I should have looked to modify before doing this whole build.
I don't mind the stock ride height and lowering it would put the body kit directly in the way of horrible NJ roads, although this isn't a daily driver. To be honest, I'd like to keep it on the track as much as possible; Englishtown is only 10mins from my house. Sadly, I'm yet to go. Let's plan something, local Zs! Dr. Venture, Duke, 1cockyz, Boomer, Zpaaji (have to stop by your shop, too)?
I've been looking to put a 07-08 350z Nismo suspension on the car. These are cheaper than new coilovers, obviously, and allow me to keep the factory height, but also be a little more aggressive in the twisties. I'll likely look for a set of hotchkis sways to complete my suspension setup. Questions and comments welcome.
Old Nov 16, 2010 | 09:40 PM
  #231
1cockyZ's Avatar
1cockyZ
I can arrange a test drive of a nismo suspension and hotchkis sway bar equipped vehicle if you like.
Old Nov 17, 2010 | 05:35 AM
  #232
kacz07's Avatar
kacz07
^That would be awesome.
Old Nov 17, 2010 | 08:07 AM
  #233
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
a NISMO is lower than a stock Z is
idle the car at 1500 or 2000? on purpose? there should not be any need...it's all in the tuning IMHO. I don't even have an idle control motor on my car at this point and it idles at 1050-1100
Old Nov 17, 2010 | 09:17 AM
  #234
Dr. Venture
<3 the Bilstiens i've got.
Old Nov 17, 2010 | 09:23 AM
  #235
Andrei's Avatar
Andrei
I swear I heard a vacuum leak. Do you have a catch can. It could be leaking.
Old Nov 17, 2010 | 09:35 AM
  #236
kacz07's Avatar
kacz07
Really? The thread I saw in the marketplace thread said they're same height and I really can't find much about it. Actually, I see that another marketplace thread said it's a 1" drop and then says it's .6" drop.
https://my350z.com/forum/socal-marke...ion-300-a.html
What is the drop, then?
Old Nov 17, 2010 | 09:39 AM
  #237
kacz07's Avatar
kacz07
I do have the P2A03 code still, which suggests there might be a leak somewhere. Upon inspection of the block, I found that there may be a valve cover leak on the driver's side as well. I also noticed oil coming from the oil cooler lines. There are def a few kinks to be worked out. When I bring the car back to RT for storage, I'm going to have them go over everything to make sure it's all good.
Old Nov 17, 2010 | 09:49 AM
  #238
kacz07's Avatar
kacz07
F your Bilsteins and your Wilwoods and your Volks. Think that covers everything I need off your car hahaha.
Old Nov 17, 2010 | 10:20 AM
  #239
Dr. Venture
LOL.............i saw you balling them all the time. hahaha!
Old Nov 30, 2010 | 10:31 AM
  #240
kacz07's Avatar
kacz07
FYI, I will be getting rid of the Megan LTHs once I get the SGs on, if anyone is interested in picking them up when they're swapped out.
