differential temps
Old Jan 7, 2010 | 05:31 PM
Ataru074's Avatar
Ataru074
Originally Posted by C Ray Z
I run 30 minute sessions and as the afternoon temperatures build I start spitting out and fluid. I have found that I burn the Mutol systhetic 75-90 oil as with Royal Purple,and Red line. I am just forced to go to this cooler. I run a Nimo rear diff. This problem has gotten worse as my times have reduced.
I went through the same issue before I sending a set of friction plates to wpc treatment, I was spilling differential fluid everywhere... now, nothing, absolutely nothing. ( I also reduced from 100% to 80% on my cusco RS)
I just have the nismo cover, the long hose, a fuel filter in the middle and the external overflow bottle.
my lap times are "decently quick"...
Old Jan 10, 2010 | 04:56 PM
mw9's Avatar
mw9
Originally Posted by SGSash
The new system will be fed from naca ducts through the rear quarter windows as well and I will start with the fans still in place just to be totally sure there is more than enough airflow through the core. Hopefully they will be more of a restriction than a help and I'll be able to remove them shortly after testing!
So you are to actually run ducts from your windows to you cooler? How well does the bilge pumps hold up to heat? Going ideas and pics
I think I will try this for a switch
http://www.summitracing.com/parts/DER-16749/?rtype=10
Thermal Switch Style Adjustable fan control kit
Sending Unit Style Thread-in
Sending Unit Included Yes
Sending Unit Thread Size 3/8-18 NPT
Fan Quantity Single/Dual
Adjustment Range (F) 150-240 degrees F
Relay Included Yes
Wiring Harness Included Yes
Manual Override Switch Included No
Air Conditioning Relay Included No
Quantity Sold as a kit.
Notes 30/40 amp relay with air conditioning override circuit. Includes 30 amp fuse. Fan amperage is critical with this unit, most dual fans with large amperage draws will require the use of two controllers.
Old Jan 11, 2010 | 07:31 AM
SGSash's Avatar
SGSash
Vendor - Former Vendor
That looks like a good kit. Just for the love of god don't use those self tappers. Or crimps. And especially not that tee-wire crimp thingy that's notorious for breaking wiring!!!
The current plan is to run NACA ducts from the rear quarter windows, we will see what actually happens over the course of the winter. The bilge fans are doing just fine, and are a good alternative to more expensive small fans.
Chris350z03
Oct 8, 2023 07:19 PM
SharX59
Sep 27, 2015 09:23 AM
Shane86
Sep 17, 2015 05:33 PM
ThreeFiveZero Z
Sep 12, 2015 04:33 PM
