1st Fully Built 5.5Gen (03) Maxima - NA
Old Apr 19, 2010 | 05:43 PM
Lightning Guy's Avatar
Lightning Guy
Originally Posted by deckdout2
Ported - Painted - Portmatched Intake Manifold
I';m liking the looks of this piece. I'm thinking the plenum itself has some promise. When you get aroudn to it, can you also post a pic of the power steering pump placement. I've been wanting to put mine on the driver's side and I think it is on the "front" side of the FWD Nissans. Also please shoot me the part number of the plunem, there is enough meat on that to really pull some thing off better than what is currently on the Z, stcok wise that is.
Thanks for posting, good luck with your build, go big!
Old Apr 19, 2010 | 08:43 PM
SatchScream's Avatar
SatchScream
Awesome!
Old Apr 19, 2010 | 10:31 PM
Mike@Blackline's Avatar
Mike@Blackline
awesome, what part of charlotte will i be seeing this around?
Old Apr 20, 2010 | 12:53 AM
gabe3d's Avatar
gabe3d
Welcome to the club and I love all the eye candy you have. Great job on doing this yourself!
Old Apr 20, 2010 | 05:23 AM
deckdout2's Avatar
deckdout2
Actually the ps pump is right below the passenger side strut. Here's a pic of where it is mounted on the Maxima motor. You don't see the pump, but you see where it goes by the bracket.
I'm usually all over the area, from Huntersville down to Ballantyne, but I live in the Ballantyne area towards Ft. Mill.
Thanks sir! You've been a great deal of help with talking to you in the past, and keeping up with the things that you have accomplished. Thanks again!
Old Apr 20, 2010 | 03:47 PM
Lightning Guy
Suck fest! daxxit. I need a FWD setup that uses the same/simlar PS pump on the grill side just as an example. grrrrr. Thanx for the effort tho!
Old Apr 28, 2010 | 04:59 AM
deckdout2's Avatar
deckdout2
4 Pulls
3rd Gear Pull
100% Throttle
1950rpms - 6500rpms
[youtube]<object width="425" height="344"><param name="movie" value="http://www.youtube.com/v/CsKRKi_fzBc&hl=en&fs=1"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/CsKRKi_fzBc&hl=en&fs=1" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="425" height="344"></embed></object>[/youtube]
Old Sep 21, 2010 | 08:13 PM
kacz07's Avatar
kacz07
Dyno plots? Numbers?
Old Nov 18, 2010 | 10:19 AM
streetzlegend's Avatar
streetzlegend
I notice by the picture of the manifold elbow that you did some work on it, did you completely remove the shelf on the elbow?
350Z_Al
Oct 29, 2020 07:44 PM
Jambo016
Sep 16, 2016 01:08 PM
35reilly
Sep 28, 2015 07:42 AM
