Custom IM on a VQ35DE Maxima
Old Feb 18, 2011 | 05:45 PM
Sparks03Max's Avatar
Sparks03Max
Default Custom IM on a VQ35DE Maxima
I know it's not a Z... but the basics apply to you guys too
There aren't many IM options for us, and the non revup Z manifold swap is a washup vs our stock manifold in "SSIM" trim... so I decided to make one in the garage.
I designed it with concepts stolen from all over the internets, including SG's testing. Big plenum volume, 3.5" elbow and intake/MAF, forcing the 70MM TB to act as a venturi and flow better than it would with equal sized piping.
Landrover MAF was used with 3.5" piping for the intake.
Pics of the whole project making it are on the maxima.org all motor forums. http://forums.maxima.org/all-motor/6...yno-gains.html
Started with hacking this up:
Ended up with this:
And the gains:
Dyno video:
http://www.youtube.com/watch?v=O0N4O-61gaE
Old Feb 18, 2011 | 06:09 PM
Barnabas's Avatar
Barnabas
National Z Club President
kinda same idea as the SSV velocity i have kudo's to you and nice fab work!!
Old Feb 18, 2011 | 06:20 PM
3hree5ive0ero's Avatar
3hree5ive0ero
Retired Admin
The inside of the plenum looks nicely filed down. Good work.
So are the dyno runs done back to back on the same day and dyno or different days? Also, were there any tuning involved before and/or after?
Old Feb 18, 2011 | 06:25 PM
Sparks03Max
Dynos are back to back within 10 minutes of each other. I had a setup with stock gaskets that kept me from having to RTV it all back together and swap fast.
Each is tuned with my UTEC (2 separate maps, but with identical timing), but I'll readily admit that the custom IM/3.5" intake tune was not nearly as well developed. I had been fine tuning and working at that stock IM/stockMAF tune for almost a year.
Old Feb 18, 2011 | 06:54 PM
archangel72's Avatar
archangel72
How does it feel on the butt dyno?
Old Feb 18, 2011 | 06:57 PM
Sparks03Max
Slightly decreased throttle response and tip in jerk because of the larger plenum. Otherwise, pulls great and sounds beautiful.
Can't wait to get my cams/valvesprings/rodbolts/oilpump installed, perfect the tune, and hit a track...
Old Feb 18, 2011 | 08:42 PM
Frostydc4's Avatar
Frostydc4
Nice fab work! What mods have you done to the car?
Old Feb 18, 2011 | 08:45 PM
Sparks03Max
Other than the intake stuff, just cattman headers/Ypipe and 3" exhaust. 350z UTEC hardwired in.
Old Feb 20, 2011 | 09:43 AM
VQ35deMax's Avatar
VQ35deMax
So how would this compare to a rwd plenum with a spacer?
nice fab work though
Old Feb 20, 2011 | 10:15 AM
Voboy's Avatar
Voboy
Impressive gains. Seems like an improvement on the Kinetix SSV design? Hope to see it tested on a Z sometime.
Old Feb 20, 2011 | 05:50 PM
Sparks03Max
The RWD manifold with spacer is basically a washup vs a regular SSIM. Judging from JayPee's SSIM dyno, this one rocks the SSIM for midrange/topend power.
The FWD Kinetix is complete junk. Mismatched ports, small plenum. I had one and promptly sold it after bad results.
Now track tested... 12.6@108 on a 1.91 60' and full weight + toolbox
http://www.youtube.com/watch?v=9IlFbR9pPUQ
http://forums.maxima.org/1-4-1-8-mil...ml#post7940919
Old Feb 20, 2011 | 07:24 PM
3hree5ive0ero
Retired Admin
Those are very respectable and impressive ET and trap.
Old Feb 20, 2011 | 07:29 PM
Sparks03Max
Thanks. Going to be aiming for some bottom 12s by fall with lots of minor changes and proper track prep of the car.
Mainly cams + supporting mods (and a higher rev limiter to match), Vmanage to control CVTC and a solid tune, serious weight reduction, removed PS belt, some underbody aero stuff, skinnies in the rear and hopefully a high 1.7 or low 1.8 '60 foot.
Old Feb 20, 2011 | 07:31 PM
3hree5ive0ero
Retired Admin
What is your current mod list and race weight (details) as of right now?
Old Feb 20, 2011 | 07:37 PM
Sparks03Max
3.5" intake/maf
Home made IM
NWP phenolic spacers
Cattman Headers/Y-pipe
3" catback
UTEC tuned
LW flywheel and UDP (others have shown gains of over 10wtq from these... Guess it counts)
Race weight today was just over 3400lbs because of all the extra junk in the car. It's around 3350 with just me and full interior... I'm a pretty hefty guy.
Pulling seats, bose, and a few other things... I'm thinking I can take that down to around 3200.
Old Feb 20, 2011 | 07:53 PM
marques1's Avatar
marques1
Nice runs. Was it mustang night on the track, all i saw were mustangs.
Old Feb 20, 2011 | 08:03 PM
Sparks03Max
Well mustangs are very popular anyway, but there was some big mustang club there.
Beating that 2011 GT down the track was pretty fun... even if he sneaked a win light by .05 because of me sleeping at the light.
There was a built bottom end APS TT G35 out there, but he was on dubs and inexperienced launching... Ran him on my first run.
Old Feb 20, 2011 | 08:06 PM
Sparks03Max
If this car were a Z, it would be pretty far up on that top 25 NA list on the drag forums.
1. AudibleMayhem ---Built Block -03 Tour 6spd 12.338@110.18mph 1.700 60ft Slicks
2. Sfarrah ----------------------03 Enth 6spd 12.876@107.81mph 1.750 60ft DR's
3. Aceman -----------------------03 Base 6spd 13.005@106.55mph 1.926 60ft Et Str
4. Veetec -----------------------04 Base 6spd 13.010@105.69mph 1.804 60ft DR's
5. 03threefiftyz ----------------03 Tour 6spd 13.027@107.39mph 1.970 60ft DRs
Old Feb 20, 2011 | 08:11 PM
marques1's Avatar
marques1
I see. Car is running strong!!
Old Feb 20, 2011 | 09:53 PM
Sparks03Max
http://www.youtube.com/watch?v=HFqxNYtk4uM
