the_coupe's NA build cp manley bc
Old Sep 14, 2011 | 06:39 AM
  #581
mgrotel's Avatar
mgrotel
make it rain man
Old Sep 17, 2011 | 03:13 PM
  #582
the_coupe's Avatar
the_coupe
welp. the motor is back on the stand. ready to be disassembled. got 2 buyers for the bottom end. anyone want some complete heads???????????
Old Sep 17, 2011 | 03:18 PM
  #583
e30cabrio's Avatar
e30cabrio
I sent the thread to a friend that might be interested in the heads.
Old Sep 17, 2011 | 04:30 PM
  #584
the_coupe's Avatar
the_coupe
awesome thanks. yeah, just updated the driver thread a few min ago. so other than the heads and block....i'll have the timing covers and timing set and the stillen crank pulley for sale, samco tube, stage4 comp clutch flywheel/clutch kit, and my single exhaust still for sale.
Old Sep 17, 2011 | 05:06 PM
  #585
Classy's Avatar
Classy
pm'd
Old Sep 22, 2011 | 06:32 PM
  #586
the_coupe's Avatar
the_coupe
she's gone.
bottom end is sold. still got the complete heads, complete timing set and covers, exhaust, and samco tube for sale!!!
Old Oct 1, 2011 | 03:46 PM
  #587
the_coupe's Avatar
the_coupe
everything is gone minus the exhaust, front and rear timing covers and the timing set (primary and secondary chains, primary tensioner, new primary guides, cam sprockets)
i'm still here if anyone has any questions or needs some tech help! i'm up in kennesaw now so i'm still down to go to any of the meets in the ATL area!!!
Old Oct 1, 2011 | 03:58 PM
  #588
e30cabrio's Avatar
e30cabrio
Tensioners are different for revup?
Old Oct 2, 2011 | 06:22 AM
  #589
the_coupe's Avatar
the_coupe
not sure. you'd have to check bro. i wouldnt think the primary side is any different, maybe the secondaries since the revups got both intake and exhaust vtc.......
Old Oct 5, 2011 | 03:44 PM
  #590
the_coupe's Avatar
the_coupe
i'm sure somebody needs a barely used stage4 clutch/flywheel kit! lol
Old Oct 8, 2011 | 08:27 PM
  #591
mgrotel's Avatar
mgrotel
Coupe, did you replace the secondary chain tensioners?
Old Oct 9, 2011 | 08:48 AM
  #592
the_coupe's Avatar
the_coupe
i did. but left them on the heads when i sold them.
Old Oct 9, 2011 | 12:50 PM
  #593
mgrotel's Avatar
mgrotel
Ok, thanks, guess I'll wait another week
Old Oct 9, 2011 | 06:30 PM
  #594
the_coupe's Avatar
the_coupe
i have all the primary t-chain stuff and and the secondary chains and water pump available tho! lol
Old Oct 9, 2011 | 06:33 PM
  #595
e30cabrio's Avatar
e30cabrio
If you can verify they will work on my REVUP, I'll take the tensioners
Old Oct 9, 2011 | 07:13 PM
  #596
mgrotel's Avatar
mgrotel
I have all the other timing stuff already
Old Oct 10, 2011 | 02:09 PM
  #597
kacz07's Avatar
kacz07
Did the secondary chains fix the rattle?
Old Oct 10, 2011 | 06:57 PM
  #598
the_coupe's Avatar
the_coupe
once i put new chains and guides on the noise went away for like 2 days. only thing that wasnt replaced were the vtc sprockets...everything was brand spankin new oem.
Old Oct 11, 2011 | 07:38 PM
  #599
mgrotel's Avatar
mgrotel
Did you lube up the chains and guides real good when putting it all together?
Old Oct 14, 2011 | 04:28 PM
  #600
the_coupe's Avatar
the_coupe
not all that necessary since the chains come oiled new in the bag and everything gets saturated after the first couple seconds of running.
