Stage 2 Cams for N/A question
Old Sep 22, 2011 | 05:52 PM
Classy's Avatar
Classy
Originally Posted by Z1 Performance
Those cams should be netting you a considerable amount more than what you've got - your headers are your main issue, and are ultimately choking where those cams would be happiest. This is most of the reason why your car is running out of steam so early in the rpm range
I don't disagree with you at all, I ran out of steam financially, and to be honest, after all that was involved, I am probably leaving it where it is. I would love to run SG's headers or Crawfords, but $$$ is the issue.
I agree on the manifold design, I am really tempted to try something if I can get a good design idea together and build up some funds, but I need to modify the valve covers to move the oil filler so it could happen
Old Sep 22, 2011 | 05:53 PM
Z1 Performance's Avatar
Z1 Performance
Former Sponsor
don't even think you would have to drop the money for either to net an improvement, but I know what you mean...at a certain point it always comes down to $$ when you're doing any major project
Old Sep 22, 2011 | 06:21 PM
Classy's Avatar
Classy
Yup, piston 6 gave up and decided to build instead of trying a junk yard motor, I can't say I regret it at all, I love how the car drives now. But it was a much longer and more expensive road to follow. Also, at this point, (and something I noticed in your thread) you start spending ALOT of $$ for small HP.
My manifold idea is to move the oil filler to the other valve cover, and make a almost kintex ish manifold but with much better execution. Instead of the log being on the passenger side, it would be on the driver side. It would be a single log manifold sloping from the tail to a large front with a 90mm throttle body facing right at where the stock airbox goes, and in a relatively short pipe have a maf and then the air filter. No more weird neck at the back, a bigger TB, a really short intake and a properly designed log. But the money to make this and to find all the problems, remake/fix the problems, make the valve covers work. Alot of work, haha
Old Sep 22, 2011 | 06:28 PM
the_coupe's Avatar
the_coupe
nonrev. made 310hp with shop temps around 100* and IATs around 112*. thats with an untouched stock nonrev lower plenum too.
Old Sep 23, 2011 | 01:59 AM
mw9's Avatar
mw9
I'd highly suggest picking up a book about engine dynamics, and reading up on how cams interact with the other aspects of the engine. It should help you really narrow your choices and hone in on what is/is not important.
You don't pick a cam by advertised duration - it really means next to nothing. There are countless examples out there that prove this. You can easily have a 260 degree cam that SMOKES one with a 272 duration.
Neither of the JWT cams you've posted will work with stock pistons.
Which would I suggest for stock, non revup pistons? Tough choice - here's why. Power on these engines is made 1 of 2 ways. Rev it (and have the parts to support those rpm's), or stroke it. Anything short of that, and you're wasting your time (IMHO). So it comes down to cams that are going to maximize the mid range because that's really all you have to work with. Which the correct choice is, again, depends on your intake manifold choice (in this case, a simple spacer will be just fine, nothing else needed and nothing exotic is required), and your header choice will mean everything.
'Aggressive' cams, however you choose to describe aggressive, are not at all what you should be looking at, because you've got nothing to support their use
Got any good books about the subject you like or have read any you think would be helpful? Looking on Amazon right now
Old Sep 23, 2011 | 11:26 AM
pchio's Avatar
pchio
All my notes show max lift on a stock piston is 11.3mm and that even is not leaving much margin for error
I have just spoken to Clark at JWT and he told me that their C2 cams will fit with stock pistons. Even their C8 cams will have enough clearance too. Any thought?
He also mentioned that to fully utilize the c8 cams, however, just as adam said, it requires a pair of good open flows headers such as SG with no CAT. Other than that, I should just stick with C2.
Old Sep 23, 2011 | 11:36 AM
Z1 Performance
Former Sponsor
not sure, I am not really familiar with their cams, only have the notes I've taken over the years to go by
any cam is only as good as the header it's asked to pump through...the two of them go hand in hand, sorta like a guitar and an amp
Old Sep 23, 2011 | 11:40 AM
Z1 Performance
Former Sponsor
Tom Monroe has some good ones
been meaning to get this one: http://www.amazon.com/Engine-Airflow...806750&sr=1-11
Old Sep 29, 2011 | 01:25 AM
mgrotel's Avatar
mgrotel
if op is only concerned about not running out of gear in the turns, he can just get taller tires, has the same affect. but will lose a little power as well
Old Jan 16, 2012 | 05:37 PM
rich2342's Avatar
rich2342
Im looking to add cams (most likely JWT based on Sg results) to my car has breather mods/md plenum spacer/hfc's/exhaust/uprev. Would I still require headers to pair with the cams? Or would I still net roughly same gains with current mods?
Old Jan 17, 2012 | 08:06 AM
Z1 Performance
Former Sponsor
A set of cams or a header or any other singular component is one piece of a puzzle.
Old Jan 17, 2012 | 04:46 PM
rich2342's Avatar
rich2342
Well, it would be the only piece i would do for now. I understand there are other components that would add to the gains.
These cam manufacturers quote hp figures ussually min 15hp on other wise stock cars. Mine has a few intake/exhaust mods and a tunable system. My thinking is I should squeeze out about 20whp additional which considering I have a non-rev DE would be good in my eyes.
Is that not feasible?
Old Jan 18, 2012 | 05:08 AM
Z1 Performance
Former Sponsor
Nearly no cam manufacturers quote gains period because it's so subjective. I don't get involved in guessing hp gains.
Old Feb 14, 2012 | 01:32 AM
ChaseA's Avatar
ChaseA
does anyone have an idea on how much a cam install would cost?
Old Feb 14, 2012 | 04:50 AM
2004Black350z's Avatar
2004Black350z
Exhaust Whore
Bout 2k I would guess
Old Feb 14, 2012 | 03:59 PM
rich2342's Avatar
rich2342
1000-1500 I think. Depending.
Old Feb 14, 2012 | 04:48 PM
ChaseA's Avatar
ChaseA
Gahhh, that blows.. i was hopin it'd be less than a g. i just got a clutch installed for like a quarter that price. Yall are talkin about the install alone right?
Old Feb 15, 2012 | 05:38 AM
  #38
Z1 Performance
Former Sponsor
Best bet is just ask some local shops - install costs can vary widely depending on the shops experience level in doing the cams, and their hourly rate. All in, about a 10 hour job
Old Dec 12, 2013 | 09:28 PM
  #39
James86's Avatar
James86
Angry question
Originally Posted by Classy
To be honest, for a non-rev, it is REALLY hard to push past 7k rpm making power. My dyno sheet shows me running out of power at about 6800, BUT I don't lose many HP to my 7k red line, I am currently running JWT C8's
To be honest, I doubt I made 1 hp from the internals... I really don't see you having a problem running bigger cams on stock internals.
Something I will say, my C8's suck in low RPM, but scream at mid and up top. Just alittle FYI
i have a question . I have the same c8 jwt cams i had my motor built and it ticks pretty loud .Louder then it did when stock.... does yours tick as such? i brought it up and they say its normal ,but i don't. i think cam timing is off or timing chain tensioners or bad.
Old Dec 13, 2013 | 03:14 AM
  #40
Suwaidi's Avatar
Suwaidi
Just to chime in, I run Tomei 264's and it ticked louder than stock until I ran thicker fluid (5W-40). Only hear accessory noise (belt) now.
